Curious: How do you install piston rings?
  • Thread starter Thread starter 5spd GT
  • Start date Start date Dec 20, 2005
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 20, 2005
  • Dec 20, 2005
Well I tore down my engine to the block yesterday. I still had factory crosshatch marks on all cylinders but my spark plugs were covered with a bit of oil so it is good to re-ring anyways.
Well the rings are pretty low tension and it seems like you could install rings by just squeezing them with my hand. I know you can use the rubber installers but rings seem easy to install into the cylinders...I didn't realize it "appears" that easy. Is the only risk of actually putting them in the walls is breaking them?
Also how do you set up rings? I know you don't want the two ring gaps to be inline with each other...so how would you set up rings on a 306?
What exactly does the oil ring do? What is the exact purpose of the first and second rings?
Thanks...
I am having Keith Craft install them...I was just curious what exactly they do and how to install them?
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Dec 20, 2005
  • Dec 20, 2005
heres a link http://www.circletrack.com/howto/1818/ hope it helps
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 20, 2005
  • Dec 20, 2005
Also, do I need to buy piston rings with my pistons or does my engine builder need to order the rings himself for my pistons?
Can I get rings that go with the pistons before the machinist sees them since they are for the pistons...?
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Dec 20, 2005
  • Dec 20, 2005
if u ordered a rebuild kit it should come with everything
EDIT: how much over is 306. i forgot. brain fart
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 20, 2005
  • Dec 20, 2005
I know it should come with "everything"...but are they "right" for the job...
306 is .030 over.
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Dec 20, 2005
  • Dec 20, 2005
306 is .030 over.
They should be right for the job. how much compression u goin to be running?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 20, 2005
  • Dec 20, 2005
About 9.7-9.8:1
Rick 91GT
Mustang Master
95
99
PA
Dec 20, 2005
  • Dec 20, 2005
Well you need to match the rings to the piston for size, ring gaps are determined by applcation, I file fit all rings. You need a rin compressor to install the pistons into the block, I also use ring pliers to install the top 2 rings on the piston with out damage. The rings will come with a diagram of how the gaps are oriented.
The top ring is the compression ring, the second ring helps keep the top ring stable.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
