i have a 2003 gt and i was wondering what to do next for power? i got these mods so far: 3:73,u.d pulleys, c&l plenum, bbk 75mm t.b,slp cat back, c.a.i, and diablo tunner........... anything would help to get me jump started. thanx ppl
start on some suspention mods like subframes and springs, then i would go with an O/R Pipe and maybe some longtubes!.. maybe a little shot of nitrous to get you hooked to the feeling of OHH ****!!
Like said above, I would work on your suspension next. SFC's, LCA's and lower your ride if you haven't already, maybe some good shocks and struts too. I pretty much have similar mods to yours and now I'm focusing on the suspension, so I'm in the same boat as you are. All that power is no good if you can't transfer it to the pavement.
thanx for this how about a procharger? i see quite a bit of them for about 12hundred witch i dont think is bad. would my car be able to handle the power or would i have to get heads cams ect. u know the works
+1 I'm doing the same. I have most of the boltons and am about to put an aluminum drive shaft on. Also as others have said work on suspension, then save for a SC down the road.
