current draw
  • Thread starter Thread starter 90StangLX
  • Start date Start date Nov 20, 2004
9
90StangLX
419
Illinois
Nov 20, 2004
  • Nov 20, 2004
Lately my car has decided that it wants to drain the battery if it sits too long without running. I had the alternator checked and it's good, and I removed all stereo fuses; draw still exists. I started removing wires from the battery side of my starter relay and got rid of the draw when I took off the wire with the goofy looking electronic piece.. I don't know if it's a capacitor, a breaker, or what, but that got rid of the draw. My question is, what does this wire go to? Whatever it connects to is causing my electrical drain. Thanks
MahFiVeOh
531
9
49
Ontario, Canada
Nov 20, 2004
  • Nov 20, 2004
I know the wire you are talking about, just replaced my starter relay last week.Sorry don't know where it goes though
Figure i'd bump it up to the top for ya.
Mustang5L5
Mod Dude
Feb 18, 2001
43,365
18,109
224
Massachusetts
Nov 20, 2004
  • Nov 20, 2004
Get a meter that will measure AMPS in DC current.
Take off the POS lead off the battery and hook up the meter in series.
With the car off, you should get less than 1.0 amps of current draw.
If you get more, start yanking fuses or removng wires wil you isolate the problem.
Then you can take it from there
HISSIN50
34
129
Nov 21, 2004
  • Nov 21, 2004
to add, in case one is not used to doing this - be sure to take into consideration known draws like the interior light (if you have the door open while pulling fuses, etc). otherwise, your head will spin trying to isolate the draw.
good luck and good advice from the ever-busy Mike.
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
