  • 1994 - 1995 Specific Tech
Cursed!
  • Thread starter Thread starter UTGAMER
  • Start date Start date Mar 25, 2010
UTGAMER
215
Dalton, GA
Mar 25, 2010
  • Mar 25, 2010
So I just took a trip soon as I turned on my road car was boggin, stopped at drive way and it didnt want to go turned it ff crunk it up idle's bad turned it off and tried to crank it, but would not start, is this the fuel pump yall were talking about? If so when I turn key to on position I can hear it soon as I turn ignition on, so would that signal it still works and is another problem?
Thanks again
woob
34
Tahlequah, OK
Mar 25, 2010
  • Mar 25, 2010
Might want to clean your MAF ? I had a problem like that, car bogging, car would start then die, let it sit for a bit, start again, car would run a little bit then die. Idled extremely rough. Cleaned MAF and the problem went away.
Also check air filter, etc. I cleaned MAF with q-tips and 90% rubbing alcohol or something, just don't use carb cleaner because you don't want any residue. Also, be very careful, the maf consists of a couple bars with these sensors between them, the sensors break off easily if you put any pressure on them. If you break a sensor, you'll be purchasing a new MAF.
And yes, that noise you hear when the key is turned is your fuel pump.
393strokervert
340
florida
Mar 25, 2010
  • Mar 25, 2010
you need to get a gauge & check your fuel pressure. @idle w/vac line removed should show close to 40psi. if it won't start, you can still check it by hooking the gauge up & watching it as someone else turns the key on.
how old is your fuel filter? might want to replace it regardless. I don't think they last as long with the crappy ethanoled gas we have now.
UTGAMER
215
Dalton, GA
Mar 25, 2010
  • Mar 25, 2010
Cleaned MAF a few days ago cause I like the power gain I got after first time cleaning. CAI is connected tight and fuel filter is no more than a month old. I dont have tools or a way to get the tools to check presure
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Mar 25, 2010
  • Mar 25, 2010
Since the fuel pump is making noise, I would start there. Like stated above, check your fuel pressure at the rail. If it's getting app. 40psi, then it's not the fuel delivery system.
Kurt
9
95PGTTech
302
20
  • Mar 25, 2010
Is spark present?
9
95steeda
37
  • Mar 25, 2010
Did you just get your car out of storage or something? Or have you been pulling parts off and cleaning, etc?? If so, what have you done? You are having way too many problems all at once.
UTGAMER
215
Dalton, GA
Mar 25, 2010
  • Mar 25, 2010
I just bought the car about a month ago. I agree there is a lot happening at once. But there is 174k miles on it
Adam95GT
2,564
Burlington, NJ
Mar 25, 2010
  • Mar 25, 2010
Mileage doesent matter as long as you take care of your car... mine has about 225k on it when i took it off the road to swap the engine... still ran perfect.
9
95steeda
37
#10
  • Mar 26, 2010
  • #10
So, just to be clear, normally, your car runs and idles fine (minus the chirping, rattling, and whining)? No rough idle or surge? This was the first time the car died on you?
I had a bad dizzy that made my car die at red lights and tough to start sometimes. Thats an expensive fix though.
UTGAMER
215
Dalton, GA
Mar 26, 2010
#11
  • Mar 26, 2010
  • #11
Yea has ran great til now, had weird idle and power loss awhile back, but cleaned MAF and and removed neg bat and it fixed it
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
