I'm taking my car in on Wednesday to get it aligned. I installed my caster camber plates, upper and lower control arms (adjustable) and stiffer sway bars, now need the alignment done. The shop I'm taking it to has experience with Foxbodys and specialize in autocross.
Does anyone have any suggestions on what kind of setup I should go with? This is not my daily driver, it's my toy. When all's done, should kick out a fair amount of HP. Right now, I'm thinking about going with a street setup that leans slightly in favor of road course application. I have more interest in taking it to a road course than the drag strip when I decide to give it some track time.
Also, are there any good websites I could look at that provide different specs? I have the Mustang Performance Handbook 2 by William Mathis, so I plan on starting there.
about alignment will try to scare you out of aggressive camber settings, claiming they wear out the inside edges of the tires. That's crap. Maybe over the course of 50,000 miles, wear will tend to show more to the inside, but in reality the thing that kills tires the fastest on the street is an improper toe setting. Negative camber will then concentrate that wear on the inside edge, and boom..."negative camber wears out inside edges".
