Here's the complete list of the old motor, peak power was around 6100-6200rpm (I use to shift at 6600rpm). Car was 3330 with driver if I remember correctly, it was quite awhile back..lol I'm looking for the dyno sheet.... The car really needed some 4:30's, I was only trapping 5250-5300 through the traps, with the 4:30's I think it would have went high 11.40's, low 50's.
SHORT BLOCK
-89 Block
-89 Stock crank, rods and piston (notched for clearance)
-AFM N-61 Cam
-FMS Steel Timing Chain
-Canton 7qt T-Style oil pan and pick-up
-Melling Standard Volume Oil Pump
-ARP Pump Shaft
TOP HALF
HOLLEY SYSTEMAX II KIT
-Holley Avenger Series Heads PT#300-575 2.02" x 1.60" valves port matched to 1262 gasket, bowl clean up and chamber polish, exhaust ports fully polished
-Holley SysteMAX II upper ported to 80mm, upper to lower port matched
-Holley SysteMAX II lower port matched to a 1262 gasket
-1" Phenolic Spacer
-75mm Accufab TB
-80mm EGR DELETE Plate (custom)
-80mm Pro-M shorty
-4" AFM Power Pipe
-Fabbed Alum Valve covers with Stef's breather tank
COOLING SYSTEM
-Ron Davis Racing Radiator
-Stewart High Flow Water Pump
-180 Degree Thermo
-16" Perma Cool Electric Fan
FUEL SYSTEM
-Walbro 255lph HIGH PRESSURE pump
-30# Injectors
-Stock rails and lines
-Paxton AFR
EXHAUST
-1-5/8" Ceramic coated Mac long tubes
-2-1/2" MAC Flowpath Off Road H-Pipe
-2-1/2" MAC Flowpath Cat Back DUMPED
SUSPENSION
-70/30 Lakewood Struts
-50/50 Lakewood Shocks
-Eibach Drag launch kit
-Steeda Chrome-Moly Sub frames
-Metco Aluminum lowers, anti squat plate not installed, Delrin bushings
-Stock Boxed Uppers
-JD's Performance Double Adjustable Uppers
-RNH PERFORMANCE Stainless Steel torque box re-enforcement kit-JDM Caster/Camber Plates
-S&W 8pt FULL CUSTOM with X brace.
DRIVE TRAIN
-3:73 FMS gears
-FMS Aluminum Drive Shaft
- Energy Suspension Tranny Mount and Frame Bushings
-Lakewood SFI Bell housing
-SPEC Stage III Clutch
-UPR triple hook Quadrant and Cable
-ROMAC SFI Balancer
ELECTRONICS
-MSD 6A
-MSD Blaster 3 Coil
-MSD Billet Dist.
-LIVE WIRES
-SPEEDBRAIN ECU
-Power Master 140amp Chrome Alternator
