cutting springs?
  • Thread starter Thread starter notchnut
  • Start date Start date Nov 30, 2008
notchnut
234
New England
Nov 30, 2008
  • Nov 30, 2008
I have Steeda springs on the Stang and I want to even out the rake just a hair. I honestly only want to drop the rear about 1/2" to get the stance I want. What is the best way to cut springs? Never having done it before I'm a bit nervous but the alternative is buying a whole new set of springs and I really dont want to do that because the fronts are perfect. The isolators are already removed from my rears as well. I'm going by the 3 finger rule, I can just barely manage 3 figners in the front but about 4 fingers in the rear. Thanks for any advise.
EPIK
796
LEFT COAST
Nov 30, 2008
  • Nov 30, 2008
Its not too hard. Just take the springs out, get a cut off wheel (if thats what there called?), & cut roughly a 1/4 coil or so off the TOP of the spring... Make a mark on the springs 1st to make sure u cut them evenly...
The only thing is, it is usually not a good idea to cut lowering springs unless they have a couple of dead coils. Most people cut stock springs...
mazen189
424
I.E. southern california
Nov 30, 2008
  • Nov 30, 2008
I would not recommend cutting springs.
Mikie
the ahead of you horseman
Aug 2, 2000
517
Belmont NC
Nov 30, 2008
  • Nov 30, 2008
Steeda springs are pretty stiff to begin with. If you cheap out and cut them, you are ruining a good set of springs and are going to ride like a horse and buggy.
mransr
1,188
36
98
Riverside, SoCal
Nov 30, 2008
  • Nov 30, 2008
have you thought about taking the isolators out on the rear? that would get a little more drop without sacrificing your springs (and ride quality)
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Nov 30, 2008
  • Nov 30, 2008
iso's are already out
EPIK
796
LEFT COAST
Nov 30, 2008
  • Nov 30, 2008
There is absolutely nothing wrong with cutting STOCK springs, but cutting lowering springs is usually not a good idea. A lot of drag racers run cut stock springs because they will give you the low look desired, still maintain stock like ride quality, & they will still be soft enough for weight transfer. As long as you have good shocks/struts, u should be fine. But I wouldn't recommend cutting the Steeda springs...
notchnut
234
New England
Dec 1, 2008
  • Dec 1, 2008
thanks for all the feedback guys, I wont cut em. I'm thinking I will just search for a set of used Eibach sport springs and just use the rears, they seem to be the springs that have the 2" drop I need to even out the rake. Thanks again,
No cutty
notchnut
234
New England
Dec 1, 2008
  • Dec 1, 2008
Here is a pic so you can kind of see what I'm talking about. If you have any recomendations, I'm all ears.
squeak93
2,352
419
164
Joplin, Missouri
Dec 1, 2008
#10
  • Dec 1, 2008
  • #10
Get different springs if u want to go lower. Sportlines should get u the look u want but will kill ur weight transfer. (I used to pull 1.9's 60s in my old 04 with street tires and sportlines).
SilverBullet01
11
#11
  • Dec 2, 2008
  • #11
I agree
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Nov 10, 2026
nfilut43
N
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
