Hey Gang,
Total newb question (again), but what does it mean if your car passes the cylinder balance test?
All I've been able to find so far is what a fail means, e.g., weak power output from a cylinder, but not so much on the "good news" end. In other words, which potential problems might a "pass" help rule out? For instance, would a passing CB test indicate good piston rings?
I got to thinking about this because I've been having some wicked blow-by, which pops out my PCV valve and grommet on a regular basis. I've read that excessive blow-by can indicate bad piston rings, so I'm wondering if (and hoping that) my positive test results can rule that out.
Note: I have tried two new PCV/grommet setups--first from Advance and second from LMR--so I don't think that's the problem. The system blows either setup out in short order (BTW, the Advance PCV/grommet looks (is?) exactly the same as the one that comes in the LMR kit--obvi didn't realize that beforehand
). Would a Motorcraft unit make a difference? I'm thinking probably not because the blow-by seems pretty fierce. One time I noticed white/gray smoke coming out of my air cleaner box, which I think I read is an indicator or super blow-by, yes? I was able to rig up a piece of rigid plastic tube--actually the one that normally goes from the oil fill tube to the intake--to keep the PCV/grommet pinned down in its hole, but I'm guessing that's not an officially-sanctioned "fix."
Haha. I just had the tube lying around because I replaced it with rubber tubing so I could pop an oil catch can in the line.
Addendum: I understand that a compression/leakdown test can indicate bad rings, but I haven't gotten around to that yet.
DM
All I've been able to find so far is what a fail means, e.g., weak power output from a cylinder, but not so much on the "good news" end. In other words, which potential problems might a "pass" help rule out? For instance, would a passing CB test indicate good piston rings? I got to thinking about this because I've been having some wicked blow-by, which pops out my PCV valve and grommet on a regular basis. I've read that excessive blow-by can indicate bad piston rings, so I'm wondering if (and hoping that) my positive test results can rule that out.
Haha. I just had the tube lying around because I replaced it with rubber tubing so I could pop an oil catch can in the line.Addendum: I understand that a compression/leakdown test can indicate bad rings, but I haven't gotten around to that yet.
DM
