Cylinder Compression Questions
  • Thread starter Thread starter Swarzkopf
  • Start date Start date Feb 10, 2006
Swarzkopf
973
Pittsburgh
Feb 10, 2006
  • Feb 10, 2006
This was previously posted in 94-95. It doesn't seem to be getting much attention so if it's okay, I'm putting it here as well.
So I did a quick compression test on my stock, 90,000 mile 95 5.0 shortblock yesterday.
I did the test on a cold engine.
Here's what I got:
1- 121
2- 126
3- 125
4- 124
5- 125
6- 122
7- 122
8- 112
According to the Hayne's manual, the cylinder compression should be over 100 and the minium cylinder should be at least 75% of the maximum cylinder, so I'm at least "okay".
However, I wonder how much performance I'm losing and how down my compression really is from stock?
Should I continue to mess with this motor, or save up and buy a new bottom end and new heads?
What do you guys have for cylinder compression? What was it stock?
Input is appreciated.
JBeezy53
559
Sacramento, Ca
Feb 10, 2006
  • Feb 10, 2006
Subscribing.....
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 10, 2006
  • Feb 10, 2006
JBeezy53 said:
Subscribing.....
Me too!
M
Marlboro_Man
437
Houston, TX
Feb 10, 2006
  • Feb 10, 2006
Well I believe you should redo the compression test with your motor up to normal running temps. But thats about all I know about compression tests.
I wish someone would do a write up on exactly how a compression test should be performed on our cars and what kind of results we should look for.
Subscribing....
JBeezy53
559
Sacramento, Ca
Feb 10, 2006
  • Feb 10, 2006
Stang D
122
Quad Cities, Iowa
Feb 10, 2006
  • Feb 10, 2006
You guys might check the 94-95 tech forum. Thread is getting a response there now.
Swarzkopf
973
Pittsburgh
Feb 10, 2006
  • Feb 10, 2006
Yeah, I feel bad about cross-posting this now.
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Feb 10, 2006
  • Feb 10, 2006
mane, its fine. i went and checked it out over there!!!
304billet
315
  • Feb 10, 2006
More important than a compression check is a leakdown test. It determines how much compression is getting past the rings. A good engine s/h between 2%-10% leakdown in any cylinder. More than 10% leakdown is indicative of needing refreshed.
A leakdown test costs about $200 and is well worth it. It will not tell u that u have bad scraper rings though, a condition that consumes oil. U could have all the cylinders below 10% but still be consuming oil because of bad scraper rings. The scraper rings scrape the oil off the cylinder walls.
I would not even think about building a motor around a 90,000 mile shortblock. I would just take the 302 bore it out .030 over and reuse the stock rods and polished stock crank, forged 11:1 SRP, Probe pistons, Comp cam XE282HR, AFR 185 stud mount heads, port matched RPM ll intake, LT ceramic coated 1 5/8", 24lbers, accufab 70mm TB, PMAS 75mm MAF. easy 375/375rwhp, NA on pump gas.
Or go 9:1 forged pistons and thow on some boost from a s-trim and have close to 500rwhp.
Swarzkopf
973
Pittsburgh
Feb 13, 2006
#10
  • Feb 13, 2006
  • #10
Problem solved...check out the other thread for details. LOL
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
