Cylinder Head Clarification
  • Thread starter Thread starter Nathan89Stang
  • Start date Start date Aug 1, 2017
  • Tags Tags
    cylinder heads mustang rockers
N
Nathan89Stang
  • Aug 1, 2017
Hello my name is nathan and im starting to do a restoration on a 1989 mustang, body is in the shop getting work and new paint so i am taking apart the motor to have cleaned, and machined as well as stroked to a 347 and i was looking at aftermarket heads and the question i have is the two choices are either stud or pedestal rockers, what is the difference, which is stock, which is better and can handle more HP and are they interchangable? in not how can i change them?
bman91gt
39
virginia
Aug 1, 2017
  • Aug 1, 2017
Stock heads have pedestal mount rockers. Stud mount rockers have a threaded stud installed in the head. They do not interchange. My opinion is that stud mount rockers are better. Stud mount rockers allow you to get aftermarket rocker arms, like crane roller rockers. Roller rockers have a needle bearing fulcrum that has less friction and may even give you a little extra power,pedestal mount rocker like the factory heads have a lot more friction.
N
Nathan89Stang
  • Aug 1, 2017
N
Nathan89Stang
  • Aug 1, 2017
What would I have to do in order to use the pedestal instead of the stud?
bman91gt
39
virginia
Aug 2, 2017
  • Aug 2, 2017
They do not interchange, unfortunately if you get stud mounted heads you will need to also buy stud mounted rockers and if you buy pedestal mounted heads the only option later on if you wanted to switch to a stud mounted rocker arm would be to pull the heads and take them to a machine shop and have them put the studs in so my advice is do some more research see which one you think will work better for your setup.
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Aug 2, 2017
  • Aug 2, 2017
I wouldn't let rockers dictate my head choice. Select your heads first, and then pick the rockers that will work with them
Reactions: Nutty 5.o, General karthief and bman91gt
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
