cylinder head question
  • Thread starter Thread starter chromedog
  • Start date Start date Jul 3, 2007
C
chromedog
554
worlds center for speed
Jul 3, 2007
  • Jul 3, 2007
the 351w in my 65 is an 85 "police interceptor" from a crown vic cruiser. ive never thought it was anything special, other than when i buy parts, it comes up a 351 H.O. well, today, i had the front accessories off (stinkin' oil pump!) and there is an "R" cast into the front of the pass. side head. it seem i read on here that this is a pretty good head for a small block.whats the deal? valves, ports, all of the above? it has always been a strong engine, even with the 2 barrel intake, and stock exhaust manifolds (it was in a ranger then)
D
D.Hearne
11,730
south louisiana
Jul 3, 2007
  • Jul 3, 2007
There were no special small block production heads in 85.
ratio411
3,870
73
109
Pensacola FL
Jul 3, 2007
  • Jul 3, 2007
I will go one step further than D...
W heads made after 75-76 are good:
Anchors
Door stops
Paper weights
Wheel chocks
Catapult ammo
Etc
rbohm
6,698
550
204
tucson,az
Jul 3, 2007
  • Jul 3, 2007
Anchors
Door stops
Paper weights
Wheel chocks
Catapult ammo
Etc
especially on the 351ci engine.
D
D.Hearne
11,730
south louisiana
Jul 4, 2007
  • Jul 4, 2007
Anchors
Door stops
Paper weights
Wheel chocks
Catapult ammo
Etc
You forgot one more use.......... excellant fodder for a scrap drive or gas money with prices where they are. In summary, small block heads from 75-76 to 86 are only worth their weight at current scrap prices.
stanger53
89
San Antonio, Texas
Jul 4, 2007
  • Jul 4, 2007
From what I remember in my Ford parts department days, the 351 PI engine was basically a stock passenger car engine except it came with a hotter camshaft. I don't remember the specs on it, but it had higher lift than the standard 351W can, but the timing events were fairly close to stock so the engine would idle nice and smooth. A little better than stock, but nothing special.
D
D.Hearne
11,730
south louisiana
Jul 4, 2007
  • Jul 4, 2007
Probably the same Marine cam the 5.0 HO engine used.
C
chromedog
554
Jul 4, 2007
  • Jul 4, 2007
mine had the frpp a-332 cam in it... i just swapped in a comp magnum in its place... because ford doesnt offer flat tappet cams anymore, only rollers. stinkin' oilpump cost me bigtime! (oil pump,cam, distributor gear, gasket set, synthetic oil change, time...) maybe that arp hardened oil pump drive shaft wasn't such a good idea
rbohm
6,698
550
204
tucson,az
Jul 5, 2007
  • Jul 5, 2007
what in the oil pump failed? the arp driveshaft is a good idea.
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
J
Engine 1995 5.0 WIP... head removal question
  • jwk72
  • Feb 10, 2019
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Mar 2, 2019
rangerbob79
R
67 Mustang Master Brake Cylinder Drum To Disk Help
  • Ceazer
  • Aug 6, 2017
2K
1965 - 1973 Classic Mustangs -General/Talk- Dec 24, 2018
Grim Repair
G
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
C
98 V6 -> 289 engine swap
  • Cerdman
  • Dec 4, 2018
3K
1996 - 2004 SN95 Mustang -General/Talk- Dec 10, 2018
Cerdman
C
