cylinder head question
  • Thread starter Thread starter fast94mustangGT
  • Start date Start date Apr 6, 2008
fast94mustangGT
60
  • Apr 6, 2008
I'm going to be cleaning my heads tommorow to get them ready to paint and bolt back up to the engine. I was planning on throwing them in the parts washer but was wondering if that would hurt the valve seals? If so how many seals are there and how hard are they to replace. I figure i might as well change them while i have the heads off since i'm not sure how many miles are on the engine because im pretty sure its been replaced at some point. any help will be appreciated guys.
dcurtis
688
Apr 6, 2008
  • Apr 6, 2008
There are 16 valve seals on your heads, and I say replace them any time you have your springs off There real cheap so buy alot, I have literally hundreds in my tool box. And they only take about a minute to replace.
Maryland Stang
1,656
30
39
Greenville, NC
Apr 6, 2008
  • Apr 6, 2008
You should completely disassemble the heads anyway before you drop it into the parts washer. It can be extremely difficult to get all of the cleaning fluid out of the ports with the valves still in the heads.
Upon removal of the valves keep everything organized and in order. The valves must go back into the heads in the exact positions that they came out of. Each valve is lapped to the seat that it sits on.
347HO
462
Seattle
Apr 6, 2008
  • Apr 6, 2008
On the flip side;
If you've tested your cylinder heads and they have NO issues, such as bad/leaky seats, leaking seals, weak springs etc... then I'd leave them alone. Clean only the outside to be painted and call it good.
IMO, it's halfassed to have your heads off and not take them down to check spring tension, have the valve seats cut, change seals, clean valves and cylinder heads, surface prep the deck.
Bullitt347
I have been doing it wrong this whole time
4,062
3,134
204
Middle of Maine
Apr 6, 2008
  • Apr 6, 2008
347HO said:
+1
On the flip side;
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
