Cylinder Head ?????
  • Thread starter Thread starter tonyvlx
  • Start date Start date Oct 27, 2004
T
tonyvlx
12
Woodbridge,Ont
Oct 27, 2004
  • Oct 27, 2004
AFR and TFS Head ???
Im going to be purchasing a set of heads soon, either AFR185's or TrickFlow Track Heats. The AFR flows roughly 26 cfm more then the TFS Heads on Intake, and both are roughly the same 192cfm exhaust at .600 lift.
Heads will be used with a TFS Stage 2 cam!!!
1.Would it be worth to spend the extra $$$ for the AFR's?
2.Roughly how much more HP is the 26cfm worth, keeping in mind exhaust
cfm is identicle on both heads?
This is for a Novi2000 blown applicatio 12psi
THANK YOU
QDRHRSE
1,590
Palmdale, CA
Oct 27, 2004
  • Oct 27, 2004
I've got a set that I'd be happy to sell you, AFR 185's that is. PM me. I'll throw in 1.6 roller rockers.
T
tonyvlx
12
Woodbridge,Ont
Oct 28, 2004
  • Oct 28, 2004
anyone
cdog301
236
richmond ,ca
Oct 28, 2004
  • Oct 28, 2004
Go with the Afr's you wont be sorry! There is a reason they are called TRICK flow mods mods and more mods!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 28, 2004
  • Oct 28, 2004
I'm very happy with my AFR's...
They are both good heads...but if money isn't an option...just pay the extra $100 bucks or so and get the AFR's
TrickStang37
292
  • Oct 28, 2004
if your ok with spendin the extra money, go with the AFR's. Will the 185 AFR's clear the pistons fine on the stock shortblock? I always thought they didnt. 26cfm is a lot and im sure under the exhaust curve they flow much better as well. if your tryin to compare the TFS heads, i think its more fair to compare to the AFR 165's IMO.
TrickStang37
292
  • Oct 28, 2004
Also, AFR 185's are only $100 more?! The TFS heads are available for $1025.
2slo93
50
Abq, New Mexico
Oct 28, 2004
  • Oct 28, 2004
Check out the flow figures on a lightly ported set of trick flows and you will see that they have LOTS of potential. where as the AFR's are already cnc'd so they are maxed out. But they are both really good heads. QDRHRSE do you still have those heads for sale?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 28, 2004
  • Oct 28, 2004
I was thinking of the trackheat heads (better flow for a supercharger as in the original post)...and the AFR 185's can clear the stock pistons...but the cam has to be downgraded...but it is possible to clear it...without replacing the pistons...
The trackheats flow between the 165's and 185's...so you can compare to whatever you like...
TrickStang37
292
#10
  • Oct 29, 2004
  • #10
i was comparin price wise. you can always find something better for more $$. and the track heats don't flow any better, they just have upgraded valvetrain hardware. i dont know why he would bother getting them if hes just using a b303 w/1.6's. He cant run too much bigger of a cam anyways witout clearancing issues.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Oct 29, 2004
#11
  • Oct 29, 2004
  • #11
go with afr heads.
qdrhorse: I sent you a PM about those heads.... did you get it?
onpoint
23
Los Angeles
Oct 29, 2004
#12
  • Oct 29, 2004
  • #12
I have a set of Trick Flow Track Heats and I love them. I choose Trick Flow instead of the AFR's because of there Twisted wedge design. Keep in mind that the Track Heats are not street legal because you can not mount the smog pump to them.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
G
What's it Worth? ⚠️ I have a brand new set of original KPI/Trick-Flow High Port Cylinder Heads, Stage 2 Ported
  • GhstRider68
  • Jul 8, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 8, 2025
GhstRider68
G
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
