I saw these upper control arm bushings on ebay and was curious to see if anyone knows anything about them. I was thinking of coupling these with some frpp hd upper control arms.
FRPP UCA's are single piece units, with rubber bushings at both ends, you can not add anything to them, besides it's stamped steel, what are you going to mate with on the helm joint?
Ok, so I cant use the spherical bushings... Should I use ford oem bushings?
What do you meen they are all the same. I thought they were different lengths 94-98 and 99-04. Any ways, do you recomend these, I know mm does.
