  • 1994 - 1995 Specific Tech
Damn BBK Equal lengths, Instal help needed
  • Thread starter Thread starter SWYZ721
  • Start date Start date Oct 27, 2004
SWYZ721
208
Ann Arbor, MI
Oct 27, 2004
  • Oct 27, 2004
So I went to a performance shop closeout, picked up what at the time I thought were BBK shorties and after taking stock manis off and trying to throw the ='s up there, realized I didn't have shorties, they were equals. So with a little use of the search button it seems as though I have to take apart the steering linkage for the drivers side header and jack the motor up for the passenger side.
Does this sound right?
Also if and when I jack the motor, which part of the oil pan should I jack, as there is only two clear portions of the oil pan, very front and very back.
Also is there any worry about damaging the trans/drivetrain and it is still hooked up and I am jacking up the motor.
Any other tips or things I left out???
Thanks to all who reply!1!!
AZ95GT
326
Arizona
Oct 27, 2004
  • Oct 27, 2004
You DO NOT have to jack up the motor. You have two options here. I just unbolted my steering linkage and it gave it the extra room to fit the header in. Another thing I have heard done was unbolting the drivers side valve cover and sliding it over, supposedly this gives you a little extra room as well. I think your best bet though is to just unbolt the steering linkage, it was pretty painless. Good luck....
SWYZ721
208
Ann Arbor, MI
Oct 27, 2004
  • Oct 27, 2004
what about the passenger side?
Numbles
998
Chicago, IL
Oct 27, 2004
  • Oct 27, 2004
With shorties I dont think you have to touch the motor. I unbolted the smog stuff, airbox, and steering linkage to get my LT's in. I did however have to raise the motor but with shorties you will not need to. You just have to try and snake them in there. Try putting them up from undernieth the car. I got the passenger in from the top, and that was with LT's.
JJ95GTID
1,141
Phoenix, AZ
Oct 27, 2004
  • Oct 27, 2004
Been there done that.
For the driver's side undo the one bolt that holds the steering linkage and install from underneath. The bolt has to come all the way out. As for the other side I had to lift the engine about 1-2" and installed the header from the top. Just unbolt the passenger side motormount and use a block of wood between the oil pan and jack. I used the rear hump on the pan. Be sure the block of wood is not pushing on the drain bolt or else it will dent the pan. Yes it is a pain but worth it.
Good luck.
Numbles
998
Chicago, IL
Oct 27, 2004
  • Oct 27, 2004
Crap
D
Drunk5oh
99
ocala fla
Oct 27, 2004
  • Oct 27, 2004
Good luck.
exactly what i did. it took about 4 hours, but we (things are much easier when youve got a friend to work with you) definitely took our sweet ass time. just do it right the first time and use some quality gaskets, those paper gaskets that come with bbk's SUCK and WILL blow very easily
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Interior and Upholstery Blower motor reinstall
  • Dontknowchit
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
