Ok to get the wheels off the 92gt. You will need a sodering iron. Cause once you get the spindles off you will see a pin in the middle of it. Take the sodering iron and put the tip in the center of the pin for a few seconds. and pull the wheel down and it will come of but be carefull cause you dont want to lose the pin cause you will need that for the new wheels. You will see how the old wheels are so hat is what you will need to do to the new wheels to make them work. get some plastic tube to make it like the old wheels. You will fab up something so the pin will fit in the tube and you will be set for the 92. As for the 87 it is way easer. Once you get the spindle off its just a phillips screw and the wheels are off. Now here is the fun part if you can fab up something to work on those spindles then cool. cause when i did my replica i bought a yellow rag top for 45 bucks and used the chrome ponys off it and the front spindlesso im good to go. but if you can fab up something to work cool. If not email gmp and see if thy can send you a set of front spindles of a new style mustang. put atten mark if you do. Hope this helps you on your first wheel swap cause once you start you will be swaping wheels on all your mustangs. I want to see pic's when your done to.
