Damn it :(
  • Thread starter Thread starter Cobra5.0Jeep
  • Start date Start date Dec 18, 2005
Cobra5.0Jeep
159
Grass Valley, CA
Dec 18, 2005
  • Dec 18, 2005
OK Some of you helped me with my "No Start when Hot" post and i replaced the computer and its starting when hot now and i can read the codes. NOW the problem i am having is a loss of power and some kind of popping noise coming from the engine and then it starts jerking. I thought it was out of gas the first time it did this because i was low but yesterday coming home from helping a family friend i was climbing a hill and it started doing this on a full tank. I had to limp it home from there I couldn't even drive up my driveway in 2nd gear! The engine temp was at 150 degrees, and it did this at 2000rpms but i've had it do it at 1300rpms as well.
Before it started jerking and making these popping noises it was very sluggish climbing the hill and then after it did it it almost wouldn't climb it at all.
ANYONE have an idea?! I thought i had fixed my problems but i guess not
Oh also today i plan to adjust the idle because its idling at 700rpms and i have an E303 cam and it really doesn't sound like its running good at that low. The vaccuum is really low at that rpm too (Yes i've looked for vaccuum leaks)
Please someone give me an idea!
thanks,
Cobra
p.s. the only code i get is 67 and its because i don't have that stuff connected.
Cobra5.0Jeep
159
Grass Valley, CA
Dec 18, 2005
  • Dec 18, 2005
If the MAF is bad would it cause this? I got a new MAF and a new IAC from our family friend yesterday.
HISSIN50
34
129
Dec 18, 2005
  • Dec 18, 2005
If it does this on command, I would run a CBT and see what it says.
Good luck.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Fuel FMU stuck?
  • JD1964
  • Sep 16, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
JD1964
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
