Damn rear quarter windows!
mustangfiveo198
145
Driving my STANG
I hate these windows. About 6 months ago replaced all the races and stuff, worked fine........until yesterday. They both just stopped working at the same time. No noise no nothing! anyone know what could be the problem now????? The front windows work fine, so not the fuse (unless the rear windows work off another fuse or something)
Any help would be GREAt.
Thanks
Faulty switch? Relay? Corrosion? Maybe double-check the fuse block, because it is possible that, as you mentioned, the rear windows operate on a separate fuse from the front ones.
Do the switches in the back still function? (Not sure if the '87-'93 models had window switches in the rear in addition to those on the driver's door, but my '86 does.) If the rear switches work, then your issue most likely has to do with the front switch(es) and/or the connection to that/those switch(es).
