DART 347, new problems...questions!!
1991vert
1,103
Ludlow, MA
ok so i got my shortblock back, finally, from the machine shop yesterday but i was too tired to touch it. i was planning on setting the lash today on the lifters/rockers and ran into a problem. first i got the dogbones on the passenger side of the engine and then when i went to put them on the drivers side, they dont fit. there is not enough vertical clearance to slide them on. so as i bowed my head in frustration i looked at the passenger side and noticed the dog bones weren't all sitting flat. the lifter came up too far out of the bore and the ring on the lifter pushes the dogbone up. that is the point where i went and got the noose and just quit.
i have heard of some "link-bar" lifters, but would those solve my problem(s)? are link-bar lifters the same as retrofit lifters? i'd prefer not having to fully break the bank with some $500 lifters. i just need something that will eliminate the dog bone and keep the lifters from rotating in the bore.
these say they're retrofit?
http://www.adperformance.com/index.php?main_page=index&cPath=191_192_195
these say link-bar
http://store.summitracing.com/partdetail.asp?part=CRN%2D36532%2D16&N=4294908331+4294840126+4294889096+4294908282+115&autoview=sku
hmm need more info. late roller 5.0 block, early 302 late or early windsor ?????? small base cam or factory 5.0 roller replacenent.are you talking about the rollers in the pic
Sportsman use stock lifters.
Iron Egale use the link bar style.
From the Dart site.
Q: What is the difference betwen the Iron Eagle Ford Block and the Sportsman Block?
A: The Ford Sportsman Block is a lower cost option based on the same casting as the Iron Eagle. It will accept the stock lifters and spider. It does not include cam bearings, freeze plugs or dowels, and it has two-bolt front and rear main caps with four-bolt centers. Available as 302 w/8.200" Deck or 351 w/9.500" deck height. The Iron Eagle Block has four-bolt main caps and includes coated cam bearings, freeze plugs and dowels. It requires aftermarket lifters and is available as 302 w/8.200" or 8.700" deck and 351 w/9.200" or 9.500" deck height.
ya but the dogbones dont have any room to be put on. there's not enough space between the lifter and the lifter valley sidewall. there are notches though. the lifter also pushes up on the dogbone when the cam lobe is at full lift
