I just got my 408w block and rotating assembly back from machine shop. Its a 97 351w factory roller block. My builder said I should consider running linked bar lifters instead of my factory dog bone roller lifters because they will handle more punishment and the cam selection is better and i would basicly be using cams designed for 5.0s if i stuck with the factory setup.Can i use retrofit linked rollers with my roller block? This is the cam I want to use with link bars, is this possible since it says for use with engines that did not come from the factory with roller cams?? 35-426-8 - Xtreme Energy™ Retro-Fit, Hydraulic Roller Camshafts, For engines that DID NOT come from the factory with hydraulic roller cams, NOT FOR E.F.I.
