Dash Removal Question
  • Thread starter Thread starter Deleted member 87397
  • Start date Start date
D
Hey all I'm removing my dash to re-wire a bunch of stuff and I have every screw I can find removed and the dash is so close to coming out but it is hung up somewhere near the steering column alsmost like behind where the gauge cluster goes. I know there must be another screw I'm missing. Do I have to drop the steering column to get to some hidden ones I can't see or what. I've removed every screw on the top, sides, and underneath, but can't seem to find this last one. My service manual for the car is in another state so I couldn't look up anything in it. Any ideas?
I dropped my steering column and removed the dash to replace the heater core. SAME thing happened to me. and i have pics to prove it. I couldnt get the whole thing out even with the steering column dropped. It was odd, but i managed to pry out the box containing the heater core without totally removing the dash. Sorry I couldn't help.
Thanks for the diagram man. It's got to be one small bolt/screw im missing. The whole dash is basically hanging there waiting to come off. I'll hit it again in the morning and see if I can find the last bolt. It usually helps me when I take a break and then go back to it later on.
my 93 car
i replace the heater corein my car and did not pull the dash it was not hard think it took about 2 hours . i have done it twice. u just move it up. been a few years since i did one. u drop the little piece that on the side down and get your hand in there to get to the bolts
Well I'm doing some re-wiring. It doesn't need a heater core at the moment, but i suppose it couldn't hurt to change it while I have the dash out. I'm contemplating just ripping out all the heat/AC stuff. I ripped out the ac a long time ago and I'm in Texas so needing a heater isn't much of an issue since it won't be seeing any DD duty. I just can't decide if I want to take the heat out too. It still works really well.
Did you finally get it out and if you did what was holding on so that you couldn't get it loose?
1 bolt under neath the dash that holds the pedal assembly to a small meta bracket attached to the dash. Haven't taken it out yet, but that's definitely what's holding it down.
