Dashboard
  • Thread starter Thread starter Sonic
  • Start date Start date Aug 20, 2021
Sonic
66
17
18
Sweden
Aug 20, 2021
  • Aug 20, 2021
Hi all,
I've a bit strange question my 95 gt's dashboard is brown and there are lot of glue trail. I've found 2001 mustang dash and seats do you thing 2001 gt dash and seats can fit on my 95 gt.
Or which model can fit on 95 gt (seat and dashbord)
Thank you & have a lovely day
Mustang5L5
Mod Dude
Feb 18, 2001
43,304
18,009
224
Massachusetts
Aug 20, 2021
  • Aug 20, 2021
So the SN95 interior changed subtly in 1999. Prior to that, the only really major change was the removal of the clock in 1997? (i think), but for the most part the 1994 interior and dash was the same as the 1998. Colors were consistent as well. The guage cluster did change quite a bit, so you need to use yours.
In 1999, the colors changed. The dash and plastics were similar, but none of the colors from 99+ will match up to 94-98.
In 2001, the radio was changed from the dual single din setup to a single double-din (or 1.5 din depending on who you ask) with a 6-disk changer. The dash and internal dash frame changes, and some of the buttons were moved around. Rear defrost went from under the headlight switch (which made no sense) to under the radio.
Seats will interchange across all 94-04's, except the colors are different starting in 99 like mentioned before
Reactions: Sonic
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,022
432
113
St. Louis, MO
Aug 20, 2021
  • Aug 20, 2021
As Mike has stated, the dash was the same up till 97, in 98 they removed the clock. You can make a 99+ work, you need to use your harnesses and modify it to move the defrost to down to the new location or slightly modify the dash and use your cluster cover and keep the defrost in the same location. It's doable, but i'm more into keeping the 94-97 Dash with the 2 single DIN spots. I just converted all mine back to original radios and cd players.
Reactions: Sonic
Sonic
66
17
18
Sweden
Aug 20, 2021
  • Aug 20, 2021
Woow i've learned lot today thanks
What about seats?
I've also one more question, that is where in US can i buy that is fordable? (in Sweden there is not so many 95's )
Mustang5L5
Mod Dude
Feb 18, 2001
43,304
18,009
224
Massachusetts
Aug 20, 2021
  • Aug 20, 2021
What about seats?
seats are a direct swap 94-04. It’s just the colors you need to worry about. 94-98 vs 99-04
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
