Daytime running light module?
Alaska5.0
73
Fairbanks, Alaska
I'm working on cleaning up all the wiring in my engine bay while I have my old motor out. One of the wires I want to delete is the Daytime Running light module inside the drivers side fender well. Does anyone know which wires I must hook together to not have any inherant effects from removing the module? Thanks
Should be P/W to LB/BK (for High Beam Indicator) & GY/W to LG/BK (for Park Brake Indicator) or you could source the DRL shorting plug and snap it in the connector. Use jumper wires to verify before committing to cutting wires.
