DDM Tuning HID Problem
M_Breeden
I changed my headlights awhile back in March and instead of the normal 9007 bulbs I now run H3 bulbs. Because of this I bought an H3 HID Kit for my car. The problem is where I am supposed to plug the stock power into the ballast doesn't fit because it's still the normal 9007 adapter. Is there some way I can get an adapter to fit or do I need to do some wiring. Anyone had this problem or have a solution?
You can remove the pins to your stock 9007 connector and plug the two pins that feed + and - to the ballast. On the stock harness the black wires are the ground, and the opposite wire is the + for low beam. the middle wire is the + for high beam. I hope this helps out.
