dead '69 ignition
  • Thread starter Thread starter klc4570
  • Start date Start date Jun 21, 2010
K
klc4570
  • Jun 21, 2010
Can anyone help with this? The battery is good, the starter cranks when I jump the solenoid. But the ignition is dead. I installed a new keyed ignition, that did nothing. Of course, after that I tested the plug with a circuit tester and there is no juice at all.
Could this be the neutral safety switch? (But wouldn't there be ACC power and the dash gauges at least jump when the key is on?)
Or am I doomed to finally replace all of that dirty spaghetti under the dash?
Thanks.
woodsnake
1,352
15
69
Hicksville, NY
Jun 27, 2010
  • Jun 27, 2010
Did you do a voltage drop test for the secondary ignition? If the starter is turning, then you are not getting any spark at the top end. Take a test light, have somebody else turn the key, and see where you do and do not have current at the coil.......Could be a very easy fix, like a cracked or broken wire.....
D
D.Hearne
11,730
south louisiana
Jun 27, 2010
  • Jun 27, 2010
Probly the neutral safety switch.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
