Electrical dead obd2 scanner
Are you saying that the PCM is removed right now? If there's no PCM or the PCM isn't getting power or ground for what ever reason, the the ODB2 scanner won't be able to talk to it.
OBTW, did you check the grounding pins of the ODB2 DLC port?
Does the mileage show up in the cluster during key on?
Does the check engine light come on at key on?
If not there's a possibility that the PCM is either dead or not being powered up.
Does the PATS system "prove out"?
Is there key on power in Fuse F2.34, F2.2, and F2,8?
1996+ Crank with no start check list
1999-2004 BJB CJB fuse panel layout:
Did you check the PCM/CCRM ground that goes around the battery onto the radiator core support?
