I had a situation like this come up not to long ago.
My "future" mother-in-law has an extra car (1996 Ford Taurus SHO) that was wrecked. It caused some issues afterwards. She took it to a local dealership at Little Rock not to long ago.
After waiting 4 hours in the waiting room she got a bill for over $2,000.
The charges were (going off memory):
- OBDII Reading - $75
- OBDII Reading - $75 (emissions)
- IRMC Replacement - $600-$800 (?)
- A/C Cycle Switch Replacement- $200
- Throttle Body Replacement - $600
- Air Bag Module Replacement - $250
- Camshaft Sensor Replacement - $220
There was some other random prices added on as well.
I knew this was ridiculous.
I went to Advance Auto Parts and got the exact same codes read for free:
DTC P0430, DTC P1000, DTC P1469, DTC P1519.
I purchased an A/C cycling switch for $15 and a camshaft position sensor from another Ford Dealership for $20.
I replaced both of them within 5 minutes. So for 5 minutes of work, I could have made $400. Plus, with the 4 hours they spent with the car they should have seen that the camshaft position sensor was just unplugged!
She told the Ford service guys that the throttle body was sticking. They said that they had to replace the throttle body ($600). With a can of carb cleaner I cleaned off the gunk from it. It worked as good as new. Again, I could have made $600, but it was done for free.
The airbag module was just a fuse that needed to be replaced.
The IRMC (Intake Runner Manifold Control Valve) actually was broke, after I opened it up, but they made it appear like it was going to be a hard swap with the crazy cost. I wired it open and unplugged it. It runs great. It initially was not opening up all the way under WOT, which created the code.
So the new breakdown of the bill is:
- OBDII Reading - FREE
- IRMC Replacement - Broke (but "fixed")
- A/C Cycle Switch Replacement- $15
- Throttle Body Replacement - FREE
- Air Bag Module Replacement - Price of a Fuse
- Camshaft Sensor Replacement - $20 (Technically free - plugged in)
Even more recently, I was working on a Nissan Altima today (L31 - 2.5L) that needed the crankshaft position sensor replaced. I asked the local Nissan dealership how much they charge per hour and they said $84.24 an hour, IIRC. It was going to cost ~ $200 to replace.
Just two simple steps to fix it:
- Remove air intake tubing and pcv hose
- Remove engine cover and locate the sensor and replace
Took all of 15 minutes and I am no Master Tech or ASE certified.
Also, I have seen a $600 fee for a check-up (change oil, plugs, fuel filter, power steering fluid, etc.) and $2000 to convert a later 80's truck to R134a, etc, etc.
What gives with the crazy prices and taking advantage of people?
I do realize that not all dealerships treat people like this, but at $84.24 x 40 hours a week x 52 weeks, that is $175,219 bucks.
Anyone got more dealership issues like this?
A local shop wouldn't do that to an old lady
