Desktop Dyno users...In here!
  • Thread starter Thread starter mustangfreak_2001
  • Start date Start date Dec 11, 2003
mustangfreak_2001
266
St Petersburg FL
Dec 11, 2003
  • Dec 11, 2003
Hey, I was toying around with this thing and was looking at Dart's specs on heads and a 351 block and with some boost I came up with this. Could you look at this and tell me what I could do better? I know I didnt do it 100% correct and I really dont know how to use it.
http://webpages.charter.net/taurusluver/corey351a.dyn
I like the #'s though
mustangfreak_2001
266
St Petersburg FL
Dec 11, 2003
  • Dec 11, 2003
heres a screen shot
88POSLX
553
Red Deer, AB
Dec 11, 2003
  • Dec 11, 2003
Well, here's an example of what changes will do...
In the first screen shot (ss), it's a 351 (not stroked like yours), with the same turbo setup. It's running the Edelbrock 6089 heads and F-cam.
The second ss is the same setup, only a wilder cam profile (comp cams).
The third ss is the same cam, only with Trickflow R heads.
The hardest part of dyno2000 is inputting flow numbers for heads and inputting cam timing numbers for cam profiles.
2MuchPSIForU
231
Toronto, Ontario
Dec 12, 2003
  • Dec 12, 2003
nice setups, but they make their power WAY too late... 5500- 8000 ?
I doubt your run of the mill 351 will sping that high but it's just for f@cking around on i guess.
mustangfreak_2001
266
St Petersburg FL
Dec 12, 2003
  • Dec 12, 2003
waaaaayy to high of an RPM for my tastes. Id like to make my power around 4-5.5K
88POSLX
553
Red Deer, AB
Dec 12, 2003
  • Dec 12, 2003
Well, once you start making 900hp, you'll need a 8-9000rpm redline so you can pull the 160mph quarters...
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 5:48 PM
from6to8
