detune an engine?
  • Thread starter Thread starter cavboy78
  • Start date Start date Jan 15, 2009
cavboy78
40
Watertown, NY
Jan 15, 2009
  • Jan 15, 2009
I have a 1970 Sportsroof with the stock 302, a T5 conversion, and a Ford 8" rear. I have a line on a 347 stroker built by a friend of mine that makes around 415hp/415ft-lbs. It is almost too good a deal to pass on, but I don't want to crush my tranny and rear end with the power. What is a common sense/cheap/easy way to detune this to a more manageable power level until i can afford to upgrade the tranny and rear end, while not doing any damage to the engine itself? Things i am thinking of now would be some sort of restrictor plate, a smaller carb, retarding the timing...Unfortunately, my right foot is not reliable enough.
mrmustangman357
763
Jan 15, 2009
  • Jan 15, 2009
just stay out of it. maybe a smaller cam or go less ratio on the rocker arms?
rbohm
6,698
550
204
tucson,az
Jan 15, 2009
  • Jan 15, 2009
best way is a smaller cam.
57fairlane
560
Oakwood, GA
Jan 15, 2009
  • Jan 15, 2009
415rwhp? Thats a nice 347 right there.
The 8" should hang in there, obviously if you put slicks on it and launch then no.
The t5 should also take that for awhile unless you like powershifting.
Basically if you just cruise around it and get on it from a roll then they should both hang in there.
I would imagine the t5 would let go before the 8" from just normal driving abuse.
cavboy78
40
Watertown, NY
Jan 15, 2009
  • Jan 15, 2009
it should be around 415 at the flywheel...my plan isn't to hit the strip so much as it would be a daily/weekend driver with trips to the track.
Hack
1,945
Minneapolis
Jan 15, 2009
  • Jan 15, 2009
I agree that the best way is a smaller cam, but you have to know what the compression is. If an engine is built for high performance the compression ratio may be as high as possible for pump gas. When you change the cam it changes the effective compression (known as "dynamic compression"). In other words, there is less bleed off from the combustion chamber with a small cam that doesn't have as much overlap, so the cylinder pressures are higher at low RPM than they would be with a bigger cam. This may cause the engine to detonate with the smaller cam. There may be some relatively simple things you can do to reduce the C.R., such as thicker head gaskets.
Just something to think about before you make the purchase. Figure out whether the CR is ok with a small cam and the gas you want to run.
Another method to make sure you don't hurt the trans or rear end is to make sure you keep small tires that aren't too sticky on the car. You may hurt the tires, though!
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Jan 15, 2009
  • Jan 15, 2009
Why not just go with some skinnier rear tires? All of the power in the world won't break the T5 adn 8" if you don't have traction...
D
D.Hearne
11,730
south louisiana
Jan 15, 2009
  • Jan 15, 2009
Hack's on the right track here. You could also limit the carb by means of a throttle stop and/or discinnecting the secondaries (if it's a 4 bbl carb)
R
RUSTYNUT
128
PDX
Jan 15, 2009
  • Jan 15, 2009
Why not just keep your current engine in the car, store the stroker and wait to put it in until you score the other upgrades. Don't forget to have brakes that can stop the car.
Hack
1,945
Minneapolis
Jan 17, 2009
#10
  • Jan 17, 2009
  • #10
Thanks for the props! Means a lot coming from you.
The carb mods are a great idea - way to think out of the box!
D
D.Hearne
11,730
south louisiana
Jan 17, 2009
#11
  • Jan 17, 2009
  • #11
That was good thinking pointing out the compression ratio factor. That's the one thing that people seem to overlook in engine buildups. Especially in SBF's
P
phutch11
328
Jan 18, 2009
#12
  • Jan 18, 2009
  • #12
Lift your right foot...
But seriously, if you've got an aftermarket ignition system why not a rev limiter?
That 347 probably has to spin pretty high to see 400 ponies - limit it to say 5000 and you ought to be safe.
Good luck...
Posted via Mobile Device
VTStang66
2,407
Rockwall, TX
Jan 19, 2009
#13
  • Jan 19, 2009
  • #13
Good luck...
I wouldn't think the car would be much fun to drive if you have an engine designed to run at high RPM and you're driving around at low RPM. Odds are that engine is peaky and driving it like grandma will be frustrating and less fun than just keeping the engine you have.
I agree that you should either change the cam and be mindful of the CR or just store it until you have the rest of the drivetrain together. Or just go ahead and break something...."if it broke it needed to be replaced anyway."
cavboy78
40
Watertown, NY
Jan 20, 2009
#14
  • Jan 20, 2009
  • #14
Hack,
I appreciate the feedback...i learned something new.
Rustynut,
Important point indeed. I do recognize the need to stop if i go. I already installed the vintage venom kit with the '04 cobra brakes on all four corners.
I have decided to get the engine and am looking at some choices for smaller cams. I like the idea of thicker head gaskets coupled with disconnecting the secondaries. Once i get that built up, I'll dyno again to measure the effectiveness. Thanks everyone for the input!
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jan 21, 2009
#15
  • Jan 21, 2009
  • #15
I don't often say something like this but, just slap that bad boy in there and drive it until something brakes. You can get a Gforce or Astro T5 that will handle the power no problem and a built 8" will take that kind of power as long as yer not drag racing all the time. What kind of tires you got in the back ?
brianj5600
1,964
Middle TN
Jan 21, 2009
#16
  • Jan 21, 2009
  • #16
HP numbers are a lot like golf scores...optimistic or even overstated. Not to mention corrected. If you are not at sea level with cool, dry air and a high pressure system, you are already giving up some HP. If the motor is not in perfect tune there is some more. A couple degrees of timing will kill some power with out hurting the motor. I would not sweat it. T5's can live if shifted nice. There are guys with way more than 415hp drag racing them, but they are not gorrilla shifting them. Buy it, run it and smile! A motor not used is a useless motor!
cavboy78
40
Watertown, NY
Jan 21, 2009
#17
  • Jan 21, 2009
  • #17
Due to the 13" rotors on the front, i needed to put 17" rims on the car for proper clearance. As such, I am running 17x9s on the rear with 275/40/17 Kumho summer tires.
I was already considering the g-force option if the t5 doesn't make it. I don't want to upgrade to a tko because of all the tunnel mods and additional parts required to install.
As for the rear, I was going to contact currie to see what they could build for me. I know the 9" would be nice, but i would have to get a small bearing rear end due to the vintage venom kit. I would think that a built 8" would suffice based on how i would drive and how much money i can afford.
Brianj5600, you also bring up a good point with the altitude as i will be moving to colorado this summer.
68RCodeConv
345
Houston, TX
Jan 21, 2009
#18
  • Jan 21, 2009
  • #18
If you try putting a mild cam in a motor in which all other components are set up for a big cam (big carb, single plane intake, free flowing heads) you are liable to make a complete dog that will not get out of its own way.
As long as you don't "shock" the drivetrain by putting on slicks or speed shifting you should be fine.
SadbutTrue
2,391
Thousand Oaks, California
Jan 21, 2009
#19
  • Jan 21, 2009
  • #19
If its a smoking deal, just retard the timing some, lean the carb, etc. Maybe put some stiffer springs on the throttle and a block under the pedal so its harder for you to slam it
And start saving the pennies you save on gas with the leaner carb for a T5z and 9".
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
For Sale 1995 Mustang GT Convertible FOR SALE
  • #16Stang
  • Jun 21, 2024
SN95 Mustangs For Sale (1994-04) Jun 21, 2024
#16Stang
