Diablo issue..
joshjwc9
1,095
17
39
Palm Harbor, FL
I have a Diablo programmer that I now use as a code puller now that my car is tuned for the Vortech. I had a misfire that I believe to be fixed after replacing the corresponding COP. I went to plug in my Diablo and it didn't turn on. I take apart the plug that attaches to the OBD2 port and two solders are broken. There are 4 wires coming to the obd2 adapter from the programmer and now there is two, the yellow and green, which are not soldered to anything!
Any direction as to where to solder them? I can see two solder points but I do not want to screw it up.
Thanks.
Thanks.
what do you mean soldered? the pins in the OBD2 plug should run into a wiring harness and all the way to the PCM , can you post a pic up ?
