P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
Assuming you have actual O2 sensors and not mil eliminators, then resetting the computer to factory will clear the codes. However, if there is an actual problem with the sensor, it may need replacing. Or the aftermarket addon that is causing the condition will need to be removed.
