  • SN95 4.6L Mustang Tech
diablo tune
  • Thread starter Thread starter v8powered281ci
  • Start date Start date Aug 6, 2007
V
v8powered281ci
  • Aug 6, 2007
just got my diablo in and was wondering how i should adjust the spark and fuel. if someone good point me in the right direction that would be great. i plan on puttin 4.10's in soon so i figured id get the tuner first so i can correct my speedometer later on
o yea its for a 2000 GT thats relatively stock..... Mac O/R H, flows, Mac CAI and a tri-ax
thanks
twogts4us
4,188
12
79
Dunedin, FL
Aug 6, 2007
  • Aug 6, 2007
Probably the best all Diablo forum on the net - http://www.modularfords.com/forums/f69/
Also, for what it's worth, I simply adv the spark all the way (10%) but I leave the fuel alone.
'03GTinFLA
486
St. Petersburg, FL
Aug 6, 2007
  • Aug 6, 2007
+1 on full spark advance. Just make sure your running good gas. It was a noticeable bump when I did mine.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Aug 6, 2007
  • Aug 6, 2007
when i got mine dyno tuned the spark adveanced all the way with a 23%enrichment to give me a good 13.4-13.7 A/F ratio
d98gt
4,505
59
204
SE Texas
Aug 7, 2007
  • Aug 7, 2007
My car is running pretty damn rich, though I don't know how much I should lean it out with the fuel trims.
I wish there were a page that gave basic info such as what a basic modded car should be in the sparkavd/fueltrim/etc while viewing the datalog. I don't know what half the things are
04fullitgt
I shower with poo
Nov 13, 2006
Crest Hill, Illinois
Aug 7, 2007
  • Aug 7, 2007
BurningRubber
1,865
24
58
Aug 7, 2007
  • Aug 7, 2007
My car pinged like a mother in 4th gear at the track with the timing bumped 5*
DO NOT JUST FULLY ADVANCE THE TIMING!!! If you dont have a keen ear to notice detonation or pinging, you running a big risk of kissing your engine goodbye if thats too much timing for it. Each car will respond different.
If you know what your listening for advance it a few degrees at a time before going all the way out. I also added a little fuel to mine because I dont want to take a chance on running lean.
04GTMustang
348
Stafford
Aug 7, 2007
  • Aug 7, 2007
i say go balls to the wall and advance her all the way in both rpm ranges. thats what i did and no pinging what so ever. Make sure ur getting good fuel and its 93 octane. but yes i agree still listen for pinging and if u hear any back it down a little bit at a time till it goes away. and if you dotn know yet when u advance ur timing thats for WOT only.
d98gt
4,505
59
204
SE Texas
Aug 7, 2007
  • Aug 7, 2007
Burningrubber, don't forget that bumping that is in percentages, not actual degrees
I have my current settings with 10% on the spark and it seems to do fine for me, even in this hot weather. Just be smart about it and run the 93 and buy from Shell/Chevron or similar.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
