Diablosport and N2O?
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
On the modify tune screen when you select timing is the retard function on the screen overall or just retarding the timing the tune has already put into the computer? Also what would be a good setting for timing with a 75 shot on a Bullitt? Thanks!
Dustin
Dustin
The choices in your "OR" statement are confusing.
Changing the timing in the Predator affects the resulting timing the EEC uses at WOT, which is based on several factors. It does not change part throttle timing.
You are also changing it for the tune that is in the Predator. It won't make a difference until you flash it into the car again.
