Diablosport Predator Owners -help-
OK quick question...Ive read numerous posts about timing advance settings to +10%. All I need to know is do I change BOTH settings?! 2k-4k & 4k-7k? Only one...the posts have been great covering this question...but noone says which one you max out? both or just one?? It seems 91 grade octane is OK to use also with the timing maxed at 10%? hmmm...interesting...Ill have to try that one out myself...93 sounds like a safer bet to me.
let me know tho guys...I wanna set it right the first time.
:cheers:
Crzyhrse said:
Yep. I'm not sure what just punching up the basic Predator tune will get you for HP, but once the Predator was dialed in on the dyno that's what I gained. Started out 257/275, ended up with 270/287 on a Mustang dyno.
You must have one of the 'monday motors' then if you were only pulling 257
now your diablo put you up to the stock baseline of a mach
