  • SN95 4.6L Mustang Tech
Diablosport question
  • Thread starter Thread starter ZINC76
  • Start date Start date Oct 4, 2007
ZINC76
9
Miami Florida
Oct 4, 2007
  • Oct 4, 2007
I was wondering why my car runs better w/ the factory Hp tune than the 93 octane predator tune.I have a '01 mustang GT w/ the following:CAI w/ drop in KnN,FMS 70mm T/B,professional products powerflow intake plenum and a UPR off-road X pipe.I spoke to diablosport and they told me that the "diablo tune" is sufficient for my modifications, I was thinking if maybe I'd fee-up the exhaust a bit more w/ a aftermarket cat-back system(currently i have the stock cat-back) or maybe its time for a custom tune.Any feedback would be great. Thanks
twogts4us
4,188
12
79
Dunedin, FL
Oct 4, 2007
  • Oct 4, 2007
How are you determining that it runs better? What happens when you are driving with the diablo tune?
ZINC76
9
Miami Florida
Oct 4, 2007
  • Oct 4, 2007
The engine seems to rev thru the rpm slower and my mph in fourth gear is at 60mph w/ diablo tune and 70mph w/ factory hp tune.Engine seems to be starving fuel or air.kinda hard to describe
Scorcher2005
883
South Carolina
Oct 4, 2007
  • Oct 4, 2007
The tune cannot possibly affect your speed. It is mechanically controlled by engine rpm, tranny gear ratio, rear end ratio, and tire diameter. I would check to see that you set the rear end gear ratio input on the tuner correctly. Say you have stock gears (3.08s) and you told the diablo (which tells the computer which sends a signal to the speedometer) that you have 3.55s, it would display a lower speed. And that pretty much matches, as 70mph/60mph=1.16. 1.16 x 3.08 = 3.57. So with you most likely rounding your speeds, I'd put my money on that.
blacksheep-1
322
Oct 4, 2007
  • Oct 4, 2007
www.racerelated.com
diablosport and sct guys.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 4, 2007
  • Oct 4, 2007
post up some dyno numbers or time slips from a track would better determine if the car is running slower with the predator tune .......
BurningRubber
1,865
24
58
Oct 5, 2007
  • Oct 5, 2007
My Diablo tune felt lazy untill I bumped the timing a little bit.
If you do this DONT just advance it all the way like some people claim you can do. Adjust in increments, go out and run the car through the gears and see if it pings/knocks at all. If it does back off the timing. I also added a little fuel to mine because I am afriad it is way lean due to my intake mods yet the Diablosport probaly leans it out a little more when the tune is installed.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Oct 5, 2007
  • Oct 5, 2007
The 93 octane tune throws more timing in than the factory HP tune does. None of the canned tunes that come stock with the Predator are all that great though. A custom tune is almost always better.
U.M.
ZINC76
9
Miami Florida
Oct 5, 2007
  • Oct 5, 2007
Replying to the PM about gears, that can't be the problem cuz my car still has the stock gears and I've never missed w/ the axle ratio in the tune, of course this is based on what the seat of my pants feeling not actaul dyno numbers. The car does'nt run bad w/ the "diablo tune" or anything, it could all be in my head.Also I switch my CAI for the stock piece(w/ K and N) to see what happens, I was running a Granatelli high flow aluminum tube for a while and I've heard that some CAI make your car run a little lean or rich depending on your set-up.So for the cars running great w/ the stock rubber intake combo w/ the FMS 70mm T/B and big mouth intake plenum.
BigDave06
39
Felton, DE
Oct 5, 2007
#10
  • Oct 5, 2007
  • #10
Your posts are hard to understand.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Oct 5, 2007
#11
  • Oct 5, 2007
  • #11
there is no way a tune can change your top speed in any gear
C
cobrasvtcoupe25
83
Bay Area
Oct 5, 2007
#12
  • Oct 5, 2007
  • #12
Get a cat-back.
twogts4us
4,188
12
79
Dunedin, FL
Oct 5, 2007
#13
  • Oct 5, 2007
  • #13
So true!
What does this mean? "The engine seems to rev thru the rpm slower and my mph in fourth gear is at 60mph w/ diablo tune and 70mph w/ factory hp tune" - at WHAT RPM are you talking about??? The same engine speed or ??? This makes no sense unless:
1. Your engine is turning at different speeds or
2. The tunes have different final drive ratios
Scorcher2005
883
South Carolina
Oct 5, 2007
#14
  • Oct 5, 2007
  • #14
Like i said before, and as others have, YOUR TUNE IS NOT CAUSING YOUR SPEEDOMTER DIFFERENCE. I gaurantee you accidentally hit a different gear ratio, or maybe it comes with a different gear ratio set on it. Check on that.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
A
Fuel & Tuning setup for upcoming 00' S/C GT Questions
  • alwayshi
  • Jun 20, 2019
SN95 4.6L Mustang Tech Jun 20, 2019
alwayshi
A
J
Looking To Tune The Gt
  • J02GT
  • Sep 15, 2017
2K
SN95 4.6L Mustang Tech Sep 22, 2017
imp
