  • SN95 4.6L Mustang Tech
Diagnosing engine knocks...
  • Thread starter Thread starter caballo
  • Start date Start date Dec 22, 2005
1 of 2 Next Last
caballo
I'm the bastard love child of a threesome gone awr
Jun 4, 2004
Colorado Springs, CO
Dec 22, 2005
  • Dec 22, 2005
You guys probably remember my engine problem that arose a short time ago. If not here's the cliff notes
spark plug ejects.
no start condition w/ various codes.
replace fuel pump
will not idle
fuel injector wide open.
trip to ford dealer-knock appears. 200.oo bill and no progress.
replace injectors, replace cop's, replace fuel pressure regulator.
NOW car idles and drives but there is a knock.
1) any tips/tricks (oil additives that might make it go away)
or
2) any advice on how to diagnose the knock ie. main vs rod bearing or maybe valvetrain...
Thanks again...:SNSign:
caballo
Jun 4, 2004
Dec 22, 2005
  • Dec 22, 2005
bump
caballo
Jun 4, 2004
Dec 22, 2005
  • Dec 22, 2005
Then again it might be "piston slap" any help is appreciated...
40th GT
916
Lawrenceville, GA
Dec 22, 2005
  • Dec 22, 2005
Piston slaps are supposed to be heard even at idle. One way to find out if a car is knocking or not, is to check the spark plug electrode color. White is a sign of knock.
caballo
Jun 4, 2004
Dec 23, 2005
  • Dec 23, 2005
I meant like rod bearing or main bearing knock. It's almost quiet at idle, but you can definitely tell when driving. It's not louder(well, maybe a little) it just gets faster...
caballo
Jun 4, 2004
Dec 23, 2005
  • Dec 23, 2005
BUMP...again
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 23, 2005
  • Dec 23, 2005
is it like a clank-clank-clank?
caballo
Jun 4, 2004
Dec 23, 2005
  • Dec 23, 2005
more like a dah-dah-dah-dah-dah at idle and then DAHDAHDAHDAHDAH as you go up in rpms.
here's what originally happened
1fast03pony
749
New york
Dec 23, 2005
  • Dec 23, 2005
this all happened from an oil change??
jees
caballo
Jun 4, 2004
Dec 23, 2005
#10
  • Dec 23, 2005
  • #10
jees
not sure... but the real trouble began when the spark plug shot out the head...
mogs01gt
3,113
30
119
Ohio
Dec 23, 2005
#11
  • Dec 23, 2005
  • #11
What are you mods and what type of plugs were you using. Stock or after market. You have to make sure you use the correct thread length on them, most people put too long of a spark plug into the PI heads.
correct threads
Does the sound seem to go away after your car hits operating temp? If so, it is probably a road knock or a wrist pin problem.
caballo
Jun 4, 2004
Dec 23, 2005
#12
  • Dec 23, 2005
  • #12
correct threads
stock replacement autolite platinums.
Sound doesn't change based on temp. sound only changes with rpm...
caballo
Jun 4, 2004
Dec 23, 2005
#13
  • Dec 23, 2005
  • #13
otra bump
mogs01gt
3,113
30
119
Ohio
Dec 23, 2005
#14
  • Dec 23, 2005
  • #14
hmm, do you see any drop in oil pressure?
triggz
1,218
Gadsden, AL
Dec 23, 2005
#15
  • Dec 23, 2005
  • #15
Send your oil off for analysis at Blackstone Labs. They'll likely be able to diagnose your problem.
They can detect trace amounts of pistons, bearings, and block shavings from unwanted friction.
Youve got a good candidate motor for this kind of test. It's only $20 too.
http://www.blackstone-labs.com/
sgarlic
3,085
Dec 23, 2005
#16
  • Dec 23, 2005
  • #16
For a knock sound that's happening while you drive, it's hard unless you have access to a lift, or have friends who will get up under the car to listen while you jack the rear end up and spin the wheels.
I know this sounds harsh, but if it were me, and I were hearing a continuous knock while driving, I'd be buying a cheap beater car to drive around while I pulled the motor from the stang to diagnose.
caballo
Jun 4, 2004
Dec 27, 2005
#17
  • Dec 27, 2005
  • #17
So I unplugged each spark plug (one at a time) while the engine was running and the sound didn't change. Then I put a piece of pcv(no hose available) up to my ear and went up and down both valve covers and didn't notice a change in volume.
So I'm thinkin' maybe it's a valvetrain or timing chain thing...
Any thoughts?!
caballo
Jun 4, 2004
Dec 27, 2005
#18
  • Dec 27, 2005
  • #18
bumpalicious
W
willit
9
Wesley Chapel, FL
Dec 27, 2005
#19
  • Dec 27, 2005
  • #19
Was your spark plug whole? (missing pieces) Entertain the possibility of ingestion of pieces. Did you do a compression test? Would rule out valve/piston/ring issues. Does the noise change with clutch in/out? Does the sound occur only under a load? Dissect your oil filter to look for any "floaters" metal, etc. How many miles on motor?
caballo
Jun 4, 2004
Dec 27, 2005
#20
  • Dec 27, 2005
  • #20
plug was whole.
Compression test good.
Auto; no clutch.
Sound is constant. increases in frequency with rpms... (slightly louder)
81k miles on motor.
1 of 2 Next Last
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
