I just pulled off my old shifter, (wasn't too hard,didn't need a piece of wood)I looked down inside an see tranny fluid where the piviot went and down inside the shifter. It this normal? It wasn't a lot, just at the base.
thanks
thanks
Are we talking about the same thing - the fill plug/sight plug? I was only aware of two plugs - a drain plug and a fill plug. The fluid level should be at or near this hole (obviously it can't be higher than this hole for too long - as soon as you pull the rubber plug out, it would start to drain out if it had too much).
