Rather than answer individually, I'll try to answer in one post:
Streethorse:
Hopefully it won't come to that, but I'll keep it in mind.
BurningRubber:
This is my first tank of 93 in quite a while. I filled up prior to installing the tune, the tank wasn't completely empty (was 87). It didn't ping until after I installed the tune, will try your suggestion in the am
d98gt:
Didn't think of that, just bought the 93 at the same place I normally get gas. Will go to Shell for the next tank and see what happens.
CobraRed:
Didn't know about the faulty batch, will check with them in the am. Thanks for the heads up.
Scupking:
Will add a little when I reinstall the tune. Thought about doing that initially as I'd read that the preprogrammed tunes can run a little lean.
Thanks guys for the help. As an aside, the detonation didn't seem as noticeable on my way home from work this evening. Is it possible that it takes a few miles for the computer to "learn" the new tune? Once again, thanks, I'll let you know how it turns out. If y'all can think of anything else, let me know.
