Did your 5-lug conversion?? IN HERE PLEASE!!!
Repostyle
538
Portland, OR
Okay, I have all the parts I could find but I need some part numbers and were to get the rest.
The list of parts I can't find:
1. SS Break lines that fit 94-95gt front and rear disc to fox body hard lines
2. Perportioning (sp?) valve
3. 3-2 port sn95 mc conversion
4. e-brake cables
basically the parts I have are the ranger axles, gt rear discs and calipers, gt rear disc mounting brackets for ranger axles, sn95 fronts complete setup, and I'm just going to hit the wrecking yard for the sn95 mc and booster.
as they say "It's the little things that kill you." This couldn't be more true.
I've seen some really good write-ups on "How-to" but I can't seem to find the parts I need to do the "how-to".
Just pick your favorite looking proportainting valve. I went with the Wilwood one from MM.
Maximum Motorsports sells the front SS brake hoses.
MM also sells the 2-3 port MC conversion.
I got the e-brake cable from Summit Racing. FMS M2809A ebrake cables for 87-92 car (2) - or 93 Cobra cables for 1993 cars (2) F3ZZ-2A635-A
FMS M2810A center ebrake cable (1)
For the rear SS lines I have no idea I just used the adapter fitting to tie into my old hard lines.
I would get a brake booster from the parts store. It is going to be a big PITA to change out 2 brake booster and install one. Your probably going to need a hammer to dent in your strut tower brace to make it fit.
Good Luck.
You'll need 2 Weatherhead 7818 line adapters for the rear, if you're going from Fox lines to 94-95 GT lines. In the front you'll need a single 7828 adapter for the passenger side from Fox to 94-95 GT lines.
As for the rest, (prop valve, cables, 3-2 port conversion) you'll have to buy those, e-bay is a great place to look. I bought these http://cgi.ebay.ca/1993-Mustang-Cob...ryZ33568QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Bought my 3-2 conv from MM and the prop valve from Ford (same as Wilwood). Good luck!
Mustangs Unlimited sells SS brakelines for Fox bodies (direct fit for stock) that have the round heads on them and THEY WILL WORK with the SN95 calipers. I know because I had them on my stock brakes, then reused them when the new Bullitt calipers went on.
Or you can get them from MM along with everything else, as stated. You can get the SN95 e-brake cables from a donor car, too.
Alright, here's what I have from MM
Part numbers:
Brake hose kit front PN: mmbk2f
proportioning valve PN: bpv-1
proportioning valve plug PN: bpv-2
MC PN: bmc-3
3-2 conversion PN: mmbak-3
Still need to find the rear ss brake lines, will stock 87-93 lines work on 94-95 gt disc?
Check this website out:
http://www.wilwood.com/Products/008-Components/002-SBF/index.asp
It seems to say they offer rear stainless steel brake lines for '94 - '04 Cobras. (Ford Mustang Cobra, Rear OE Replacement (1994-2004)) I would call or e-mail them however and ask if these are just OEM rubber or SS OE replacements to be sure.
Part # 220-8595
This was the closet thing I could find to someone offering rear SS lines for a Mustang. They also list components if you're up to fabricating your own rear SS lines. Good luck!
damn I hate the word "Backorder", ship date is for around 8/18. Oh well, I guess that gives me a little more time to get my gears setup. Still looking for the rear ss lines, would it just be easier to change the rearend to sn95 hard lines?
