Did your firewall do well?? (leak test)
I doing some research on firewalls and came across a leak down test and noticed how bad my firewall did (Zonelabs free). So I chose another based on that test, just wondering what you run and were it stacked up on the test (if it was included). BTW I chose Sunbelt Kerio Personal Firewall but I may dump it for Jetico as it scored even better.
http://www.firewallleaktester.com/tests.php
Danny, once again I barely understood that, but am subscribing since I run the same FW as you used to (ZL free).
If you're on dial-up, does it matter much? Mine lists that it's blocked 130K access attempts. :shrug:
Good luck with the research and implementation of the new stuff. :nice:
I was on dial up until I moved to SC and pretty much hakers target those on broad band. You really don't have much to worry about although better safe then sorry. Honestly JT if I were you I would run the Sunbelt Kerio Personal Firewall as it has options to block ad banners ect which will speed up loading of pages. I just unistalled Keroi and installed Jetico and so far there are a lot of pop ups asking what programs you want allowed. So far it has blocked A LOT of programs trying to enter.
Cool, thanks Danny. I didnt reply earlier because I was afraid I had already derailed your thread. :(
I'll read over the Kerio product. I like having it ask me whether to load something (matter of fact, the pages here don't load half the time because I wont let it DL something for the moving banners or something else on SN. It's a pain but I like having control, I guess).
Thanks Danny!
GRC Port Authority Report created on UTC: 2006-10-03 at 00:03:46
Results from scan of ports: 0, 21-23, 25, 79, 80, 110, 113,
119, 135, 139, 143, 389, 443, 445,
1002, 1024-1030, 1720, 5000
0 Ports Open
0 Ports Closed
26 Ports Stealth
26 Ports Tested
ALL PORTS tested were found to be: STEALTH.
TruStealth: PASSED - ALL tested ports were STEALTH,
- NO unsolicited packets were received,
- NO Ping reply (ICMP Echo) was received.
Your system has achieved a perfect "TruStealth" rating. Not a single packet — solicited or otherwise — was received from your system as a result of our security probing tests. Your system ignored and refused to reply to repeated Pings (ICMP Echo Requests). From the standpoint of the passing probes of any hacker, this machine does not exist on the Internet. Some questionable personal security systems expose their users by attempting to "counter-probe the prober", thus revealing themselves. But your system wisely remained silent in every way. Very nice.
you guys expecting a hack attempt on your computers?, only reason I would worry too much about this is if you run a server of any type off of your computer. I would be more worried about spyware/virus protection than a good firewall. But a firewall is a good thing to have. A good firewall is a hardware firewall such as a router.
