jbritt1234 said:It's VERY valid when it's your only car and you want to be able to drive it on the Interstate without you ears bleading you fu**ing dry.
If you do not have a helpful answer, stfu.
Red03Mustang said:Gee guys. Thanks for the war.![]()
Anyway. The point of getting rid of the drone is that my car is rattling all over because of it. Things buzz from the sound because they are being vibrated too much. Therefore, I want a quieter exhaust.
If my car didn't buzz, I would't care. I'd probably like it louder.
I have an auto, not a manual. I don't control what RPM I cruise at. I have 4.10s already - someone responded 'get gears'. The gears make 60mph the drone range. I usually drive 60, so... that is my whole point.
For those of you who gave me decent responses, thanks.
I will look up the baffled mufflers mentioned before. They might be a consideration. I think, because of money, I will be using stock mufflers and the catted x.
Gearbanger 101 said:On that note, from what I understand....Borla and Magnaflow make the quietest mufflers, but the Bassani baffles may not be a bad idea, if they're as cost effective.
streetstang03 said:louder exhaust covers those rattles nicelycatted xpipes and stock mufflers actually sounds pretty good. a guy in my parents neighborhood has it on his cobra and it sounds really good...a little stuffy, but good. Another good combo to try is catted xpipe and magnaflow catback. not too much drone w. the magnaflow. my aunt has magnaflow catback and stock hpipe on her 03 GT and there is a lot less drone than my flowmasters. After you get the catted xpipe on w/ the stock mufflers, if you want louder or a different sound, switch to a magnaflow catback.
Blev said:Sorry bro, didn't mean to go nutzo on your thread, but that guy needed to stfu after he told us too for giving our input. Granted it wasn't exactly the answer you were looking for, but it was input. heh..heh...
Good luck with your exhaust choice.
I would've kept them on had I known I was going catted X later. It probably would've been the perfect matchup.
With the stock H, Magnaflows are very quiet. The only time you will hear them at all is at the 2000rpm range. Slight drone - very slight. They are supposed to make really good power though!Just curious Red03, do you remeber what model of Magnaflows you were using? Were they XL's? What length were they? I'm probably going with a set on my Cougar, but I want the quietest ones possible. I'm sick of the noise and to tell you the truth, would rather hear the whine of my blower over the drone of the exhaust.Red03Mustang said:All right.
Also, someone mentioned magnaflows being quiet. Yeah, they are. They are really quiet. In my car, they were quieter than stock when cruising.I would've kept them on had I known I was going catted X later. It probably would've been the perfect matchup.
Gearbanger 101 said:If I recal, the Dynomax have been regarded as one of the quieter set-ups as well. I don't think you made a bad decision. How does it sound with the Dynomax on it?
It just means that you're hard of hearing in your left ear.Marine One said:There is a slight drone at around 2100 rpms, but nothing like the Flows had. I bought the car about a 4 hour drive away from where I live, and the drive home was unbearable. Interestingly the drone is louder in the drivers seat than on the passengers side. This car is also a convertible, so I don't know if that has anything to do with it.
Gearbanger 101 said:Just curious Red03, do you remeber what model of Magnaflows you were using? Were they XL's? What length were they? I'm probably going with a set on my Cougar, but I want the quietest ones possible. I'm sick of the noise and to tell you the truth, would rather hear the whine of my blower over the drone of the exhaust.![]()
So I'm fed up at this point. How much of your trunk did you Dynomat? With my current setup, there are times when the change in my rubber cupholder starts rattling, which is the only gripe I have with drone. In the near future I am planning on an x-pipe, but at the same time I don't want the inside to get too loud (lookin' out for the dates in the car). I had thought of Dynomat in the past, but I didn't know how much of a difference it would make. Is it really that much better?menasci said:When I had my Dr. Gas it droned like crazy!
Threw back on the Stocker H, and drone was minimized.
I dynamated my trunk and it made a big difference!
CRZYHRSGT said:How much of your trunk did you Dynomat? With my current setup, there are times when the change in my rubber cupholder starts rattling, which is the only gripe I have with drone. In the near future I am planning on an x-pipe, but at the same time I don't want the inside to get too loud (lookin' out for the dates in the car). I had thought of Dynomat in the past, but I didn't know how much of a difference it would make. Is it really that much better?
Also, I've noticed the drone being worse with the windows all the way up. Try cracking the driver's window an inch or so, and see if that helps. Accoustically it makes sense (interior exhaust has no where to go with the windows up. It's like porting a speaker box).
