bnickel
At the back of the carb.
In this pic (not my carb, I stole the pic off of ebay), where that nut looking thing is sticking out of the middle of the back; mine has a barbed thing there that a hose can connect to. We originally had a hose running from there to the valve cover cap, but now we have it capped off.
-Chelle
that port is an alternate PCV port. if it was connected to the breather cap you had a definite vacuum leak from there.
i would still bump the timing up a few more degrees to about 12-14 and also check the condition of the gas tank and definitely replace all the rubber lines. there should be one at the tank that connects to the steel line under the car and one under the driver side front floor support (frame rail) and one connecting the metal line to teh fuel filter. from the pump to the carb whatever rubber lines are there need to replaced as well.
i'd drive it for a few days before you do anything else just so you don't add to the problem in case it still exists.
