  • SN95 4.6L Mustang Tech
Diff. fluid change
  • Thread starter Thread starter stonewall621
  • Start date Start date Apr 16, 2007
stonewall621
12
Charlottesville, Va
Apr 16, 2007
  • Apr 16, 2007
Damn, I just changed my rear diff fluid for the first time since i've had the car and man is it a pain in the *ss. Does anyone have any tips to make this any easier?:SNSign:
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 16, 2007
  • Apr 16, 2007
You shouldn't have to do this often. Just make sure you put the right weight oil in and use some friction modifier. You should be good to go for a long time.
D
Dragstr05
643
Stafford VA
Apr 16, 2007
  • Apr 16, 2007
Easier? Lucky for me I work in a shop and have a driveline machine with a long hose that just pumps the oil right in, nice and easy. Was a messy job, but easy.
But as mentioned above, you really dont have to do this often. If its that much of a PITA, maybe you should just consider taking it to the dealer just to have the diff fluid changed next time and let them worry about it.
forum155pl
520
the 509
Apr 16, 2007
  • Apr 16, 2007
i take the sway bar off and i jack up the body of the car so the axle hangs.. piece of cake...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 16, 2007
  • Apr 16, 2007
There is no need to remove the swaybar.
You can get a FRPP aluminum diff cover with drain and fill plugs to make it easier.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Apr 16, 2007
  • Apr 16, 2007
i agree with KT i bought it for my 5.0 and it looks nice
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 16, 2007
  • Apr 16, 2007
the covers are nice, but if you have a panhard bar it covers the drain plug. when i tear my diff apart im going to drill a hole in the bottom and put a drain plug directly in the case.
lvmustanggt
721
Las Vegas
Apr 16, 2007
  • Apr 16, 2007
How many quarts ? Last time I change mine , I fill it up till it came out of fill hole so it was leaking from every where. Now it's not leaking so I think it fine.
G
GettinThere
553
Central Texas
Apr 17, 2007
  • Apr 17, 2007
I don't think you are supposed to fill it to the fill hole, that would be overfilling it. I think it takes 4.25 pints, which would be about 2 quarts and the friction modifier.
stonewall621
12
Charlottesville, Va
Apr 17, 2007
#10
  • Apr 17, 2007
  • #10
do all GTs come with a posi rear end? I changed the fluid to rid my car of a bad rear end noise, the new fluid helped quite down the noise but it's still there just not as loud, i didn't add the friction fluid should i?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 17, 2007
#11
  • Apr 17, 2007
  • #11
Yes, you need four ounces of friction modifier in there.
stonewall621
12
Charlottesville, Va
Apr 17, 2007
#12
  • Apr 17, 2007
  • #12
what do you guys think about royal purple gear oil? they claim that their fluid has the addictive in it
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 17, 2007
#13
  • Apr 17, 2007
  • #13
I do not like RP but it does already have the needed friction modifier in it.
G
GettinThere
553
Central Texas
Apr 18, 2007
#14
  • Apr 18, 2007
  • #14
To support what McTeague said:
From the Royal Purple website: "All viscosities of Max-Gear are formulated with hypoid friction modifiers necessary for use in clutch or cone type differentials. No additional additives are necessary."
steve_stang2003
195
#15
  • Apr 18, 2007
  • #15
I did my 2003 GT a couple of months ago.
I used Mobil 1 Synthetic 75W-140 and added the modifier even though Mobil says they have it in the oil already. The reason I added more was because the label says something like "you might wish to add additional modifier for high performance applications" or something like that.
FWIW it wasn't too bad, but dang does that oil STINK!!
And believe me, anything it gets on, like cloths, are shot for life.
Tally_4.6
195
Orlando
Apr 18, 2007
#16
  • Apr 18, 2007
  • #16
steve_stang2003 said:
FWIW it wasn't too bad, but dang does that oil STINK!!And believe me, anything it gets on, like cloths, are shot for life.
This man speaks the truth, i have yet to come across a gear oil that doesn't reak other than ATF. And that Ford friction modifier is just as bad!
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
