Diff Fluid
  • Thread starter Thread starter snoboardcore
  • Start date Start date Mar 14, 2006
snoboardcore
276
New Hampshire
Mar 14, 2006
  • Mar 14, 2006
Just change my diff fluid in my car how much am i suppose to put in?
timewarped1972
642
mesa, az
Mar 14, 2006
  • Mar 14, 2006
untill it runs out the fill plug i believe, assuming your using the stock fill plug
snoboardcore
276
New Hampshire
Mar 14, 2006
  • Mar 14, 2006
i put in 2 quarts think i should add more?
timewarped1972
642
mesa, az
Mar 14, 2006
  • Mar 14, 2006
i believe the text book way is like anything that has a fill plug......fill it till it starts to run out......or, fill it untill you can atleast touch the oil level with your pinky finger if you can get it into the fill hole....
JBeezy53
559
Sacramento, Ca
Mar 15, 2006
  • Mar 15, 2006
If I remember correctly the capacity is a little under 3 quarts.
squeeeg
1,905
Michigan
Mar 15, 2006
  • Mar 15, 2006
It is definately more then 2 quarts so put in another one. It will run out when it is full.
Biggeley
136
  • Mar 15, 2006
The "text book" says to fill with 2 quarts of synthetic fluid... However, you typically can put in about 2.5 quarts until it starts weeping out of the filler hole. Most people just fill until it drips out the filler hole..
Make sure you are putting in friction modifier with the new fluid. Otherwise your limited slip is gonna bind on you going around turns...
snoboardcore
276
New Hampshire
Mar 17, 2006
  • Mar 17, 2006
what is friction modifier? I have limited slip additive if thats the same?
87ttopstang
342
Ontario, Canada
Mar 17, 2006
  • Mar 17, 2006
Just did mine last week with Mobil 1 and friction modifier. It took about 2.7 bottles (liters). As said above, you will know when it is full. It will come out the fill plug.
troyGT03
278
too close to memphis,tn
Mar 17, 2006
#10
  • Mar 17, 2006
  • #10
its more than 2 less than 3. fill until it runs out. most of the synthetics have friction modifiers built in.
snoboardcore
276
New Hampshire
Mar 19, 2006
#11
  • Mar 19, 2006
  • #11
I used valvoline high performance gear oil. Think it has the additive in it already? i used an 80w-90 if that matters.
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
D
Drivetrain Will a broken s spring affect traction?
  • dqureshi06
  • Jan 12, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
Mustang5L5
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
