Diff modifications?
MUSTANGJOE
Silver Stanger
1,644
I've got posi traction!.? does this come stock on a 92 Gt?, also Should I modifie anything else in the diff since I'm putting 3.73 gears?..motor/tranny are stock. :)
Thanks
and it is called Trac lok if you are looking for a rebuild kit. you can play with the clutch packing to tighten it up over stock.
good luck.
I don't need a rebuild. I have posi traction...Is this called trac lock as well? Both back wheels spin in the same direction at the same time. Does installing 3.73 gears make it hard on the stock diff and would it cause it so break? My gears came with some bushings, is this all I need to do a good job? Thanks guys!
