Diff took 4 Qts?
  • Thread starter Thread starter 88-378
  • Start date Start date Apr 16, 2008
88-378
14
Alpharetta, GA
Apr 16, 2008
  • Apr 16, 2008
Why so much? And i still can't touch the fluid by sticking my pinkie in the fill plug hole?
Bullitt347
I have been doing it wrong this whole time
4,017
3,006
204
Middle of Maine
Apr 16, 2008
  • Apr 16, 2008
One possibility is that the rear end is at a angle and all of the fluid is running into an axle tube. Should take only 3 qrts at most.
P.S. You measured qrts and not liters, right?
88-378
14
Alpharetta, GA
Apr 16, 2008
  • Apr 16, 2008
i uses 4 32 ounce bottles of Lucas gear oil with 5ounces of friction modifier.
The car is on level ground and when i put my pinkie in the fill hole it doesn't reach the fluid.
I also have a FRPP girdle if that makes a difference.
88-378
14
Alpharetta, GA
Apr 16, 2008
  • Apr 16, 2008
anyone else? Should i drain some fluid?
C
canesstangnitro
109
Metairie, LA
Apr 16, 2008
  • Apr 16, 2008
I just did mine when I did my axles and it took 3 quarts. One question this thread made me think of. If I forgot to put friction modifier in with the gear oil, can I still do it now. I have only driven it like 5-10 times since I put it in. What kind of harm can be done if you forget to put it in?
R
redneck15431
83
Apr 17, 2008
  • Apr 17, 2008
It will ruin the clutches in your trac lock. If you just had the rear end rebuilt it would be a good idea to put it in now so you don't have to rebuild it again. If you go to your local ford dealership they should have it for like 5 or 10 bucks...I can't remember.
C
canesstangnitro
109
Metairie, LA
Apr 17, 2008
  • Apr 17, 2008
I did notice that it has been a little harder to shift since then. DO you think that any damage has been done if I have drove it 5-10 times without the modifier? I ordered it today
HISSIN50
34
129
Apr 17, 2008
  • Apr 17, 2008
FM lowers the coefficient of friction. This reduces the lifespan of the clutches but is done to keep the rear from chattering. Running with no modifier just means the rear could chatter while each wheel is at different speeds (with regard to one another). The clutches themselves would actually thoeretically last longer however. Auto-X guys routinely run without FM. FWIW, I use synthetic fluids with some modifier (in the formula) and don't add any extra.
88, are you putting your pinky in the factory fill hole? That's the one I would use. Your girdle's fill hole might be higher up than the factory one. If too much fluid is introduced, you can start blowing some out the vent.
Good luck to all.
88-378
14
Alpharetta, GA
Apr 17, 2008
  • Apr 17, 2008
Good luck to all.
I'm going to drain it and refill with 21/2 qts.
HISSIN50
34
129
Apr 17, 2008
#10
  • Apr 17, 2008
  • #10
I wouldnt even go that far. With the car totally level, there's no reason why you shouldnt be able to remove the factory fill plug and add or remove fluid as needed.
You could even use something like a piece of bendable metal (coat hanger, etc) to dip through the hole. This might give a better idea of where the level is at (just dont drop the metal rod).
L
lang williams
567
cleveland, oh
Apr 17, 2008
#11
  • Apr 17, 2008
  • #11
I've heard most of the "name brand" dif fluids have all the additives you need already. just add some FM if the dif is noisy.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 19, 2008
#12
  • Apr 19, 2008
  • #12
the girdle fill hole isnt the same level as the 8.8 fill hole. You should remove your factory plug and fill from the girdle fill hole till the fluid is at the same level as the factory hole.
88-378
14
Alpharetta, GA
Apr 21, 2008
#13
  • Apr 21, 2008
  • #13
Thanks to all. But since i started hearing a horrible noise coming from the driver side rear, sounded like a bearing)? i called my mechanic and told him to send a flat bed and do the rear again.
If he doesn't get it right this time, we'll have to talk about him buying me a completely new rear from Curry or FRPP. I really am getting sick of this crap with this rear!
With the money i already spent, it was cheaper to buy a complete rear already assemble except for brakes!
Lesson learned when you can't find a good shop near you!
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Apr 21, 2008
#14
  • Apr 21, 2008
  • #14
Yeah, fill it though the factory hole in the front of the pig. I made the mistake once of filling it through my girdle cover, and it would leak out of the axles seals and mess up my wheels. It made them super dirty because dirt stuck everywhere the fluid was.
2-1/2 quarts is what it should take.
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
