  • 2.3L (N/A & Turbo) Tech
Difference between 2.3Turbo and 2.3N/A blocks?
  • Thread starter Thread starter 89projectstang
  • Start date Start date May 18, 2006
89projectstang
64
  • May 18, 2006
I have a 2.3 turbo engine that im building but the block seems to be cracked, nothing due to stress but where the engine would bolt up to the engine stand, one of the holes have broken off. I have a spare 2.3 n/a block...if I take all the guts outta the turbo block and put it into the n/a block it should be ok righT?
tahnks,
matt
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
May 18, 2006
  • May 18, 2006
The only difference is the turbo block has an oil drain for the turbo. It drains back into the block, right above the oil pan. You could always fab something up for the oil drain. Otherwise, they're exactly the same.
89projectstang
64
  • May 19, 2006
heh
i thought so, so the oil drain from the turbo to the block....so i could technically fab something from the turbo to the oilpan itself?!
thanks,
Matt
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
May 19, 2006
  • May 19, 2006
That'll do it! Just make sure it enters the pan high enough so it's above the oil level.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 25, 2006
  • May 25, 2006
It actually sounds easier to drill and tap a 1/4" NPT hole(or whatever it is) where the turbo drain is..
89projectstang
64
  • May 29, 2006
lol ok, im stupid....on which part would the turbo drain be on? (i havent looked at my engine in a lil while)
65ShelbyClone
4,675
38
119
May 29, 2006
  • May 29, 2006
It should be a raised boss on the exhaust side of the block above the pan rail.
88stangmangt
2,332
Stafford,VA
May 29, 2006
  • May 29, 2006
you could do that or if your nerves about drilling the block i have seen the oil cap drilled and tapped with success...i would rather tap the oil filler cap than the block or the oil pan.
89projectstang
64
  • May 29, 2006
drilling...
most likely id be taking either the oil pan or the block to a shop and have them drill it (im chicken ****) thanks for all the advice. Im not going to have this engine done and rebuilt for a while, however, so i should be ok. Any suggestions on a good shop around central texas to take it to ?
thanks again for all your help guys!
matt
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
May 31, 2006
#10
  • May 31, 2006
  • #10
MDS Engine Service
15156 South IH-35
Bruceville, TX 76630
254-857-8545
They're just south of Lorena. They built the shortblock for Thunderstang.
Keasbey
915
Montreal
May 31, 2006
#11
  • May 31, 2006
  • #11
I drilled it myself, and no problem since.. *knock on wood*
Brantley
1,329
Memphis, TN
May 31, 2006
#12
  • May 31, 2006
  • #12
So are you saying the oil will drain up hill against gravity to a point higher than the oil drain on the turbo? I'm having a bit of difficulty seeing how this would work.
Guys, tapping the pan is easy, and that's definitely the best place to put the drain. Forget the stock drain location. That is so tight and hard to work with, you'll be cussing yourself in the future for not draining to the oil pan. Going to the pan will save you a ton of trouble and frustration later on if you ever plan on pulling the turbo off. Just use a -8 AN line.. the turbo side drain flanges can be found on ebay at a very reasonable cost, and just have an AN male fitting welded on the oil pan. Connect hose. Very simple. Pictures of this setup can be found on my website.
88stangmangt
2,332
Stafford,VA
Jun 1, 2006
#13
  • Jun 1, 2006
  • #13
not saying i have done it but i think it was even the new MM&FF mag supercharger shootout or something...where they used that method....and didnt have a problem....
Brantley
1,329
Memphis, TN
Jun 1, 2006
#14
  • Jun 1, 2006
  • #14
I know what you're saying, however, I just can't picture how that would work unless the turbo was mounted above the hood or something. Beats me.
Anlushac11
2,270
Indianapolis, Indiana
Jun 2, 2006
#15
  • Jun 2, 2006
  • #15
There was a item displayed recently in one of the Mustang mags that was a drain back fitting that was designed to be attached by the home user on the side of the oilpan.
It was a cast metal two piece part that bolted together over a hole you drilled in side of the pan I think.
I thought it was from Dugan racing but I cant find the magazine it was in now.
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Today at 9:08 AM
Lapping2632
L
What in gods green earth happend to my N/A 2.3?
  • Piranahbite
  • Mar 24, 2024
2K
2.3L (N/A & Turbo) Tech Jun 1, 2024
Piranahbite
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
