Difference between 4 Cylinder Body and 8 Cylinder Body?
ynhrgt
Was thinking of maybe just doin a 5.0l v8 swap into a 4 cylinder stang. Is there anything mechanically different between the two body types?
If there is too much of a difference, I'll just start with a car with originally a v8.
well, besides from the obvious (engine, trans, rear end) there are a good amount of other little differences. It's quite a big project to undertake. Run a search, you'll find some good info
edit: mavrick beat me to my reply..you're just too quick for me
Well, I meant PHYSICALLY different.. I understand springs/trans/etc.. all that is different.. but is the actual structure itself any different.
I plan on doing everything over again anyways, I was just wondering if a 4 cylinder body can handle an 8.
mustangman33 said:
I tried that swap on a 4cyl 90, pulled the motor out and went to put in a v8, and the kmember was different.
I 've heard that the k-member was the same between the 4-cyl and 8-cyl, and that the only different one was for the 3.3L inline-six (!). Can anyone say for sure, what is true? Sorry for thread-hijacking, but I am interested to know this.
sorry to disagree but the crossmember is the same, at least in a fox body.
unless you have a inline 6 like a fairmont, the 79-93 fox body crossmember is the same no matter if you have a 4 or a 8.
Why i know?? bc i have done the 2 swaps.
It's ok. So, what I've heard is:
(for the years 79-93)
I4 K-member = V6 K-member = V8 K-member
I6 K-member = nothing
Single exhaust crossmember = all 4 & 6 cyl's, 79-85 V8's
Dual exhaust crossmember = 86-93 V8
Also, 90-93 tie rod ends are better with bump steer than older ones.
90-93 cars have larger front fender openings, useful for big tires :D
90-93 cars have a driver's airbag, which may or may not save on insurance
V8 and I4 cars have different ratio racks and different pumps. DO NOT interchange the two.
I4 cars are not equipped with quad shock mounts as mentioned, nor do they have a pinion snubber.
I really don't need to say anything about mass air, do I? :D
I picked a 4-banger cuz it wasn't all beat to hell :p
