Difference between K&N CAIs?
I'm confused as to the difference between the two products I'll describe here. Maybe it's the price difference and the performance difference, but any help would be greatly appreciated.
A sister product to our 57 Series FIPK, our 63 Series Intake Kits or AirCharger® Intakes are built for many different vehicles and represent a dramatic improvement over a K&N O/E replacement filter alone. They enjoy a faster speedto market than our 57 Series kits due to their pending CARB status. These intakes use only non-metallic rotationally molded tubes that can reduce intake air temperature and decrease intake sound over a metal tube. Restriction can exist BETWEEN an air filter and the engine reducing the benefit of a K&N Air Filter. The weakest link in the airflow "chain" robs a vehicle of its natural horsepower. Often that weak point is the factory air path leading to the Engine. K&N Air Intake Kits virtually eliminate air path restriction by replacing the air filter and the entire air path to the engine. The aerodynamically engineered tube drives a massive amount of air into an engine, which translates into POWER. 63 Series Intake Kits are not legal for street use in some U.S. states.
Cost: $253
Expected HP gain: 15 hp
Built for performance and show, the Typhoon™ Air Intake System is a free-flowing mandrel-bent aluminum tube induction system designed to fit many sport compact performance vehicles. Typhoon intakes come in one of three designs; cold air intakes (CA), short ram intakes (SR), or complete cold air (CCA) intakes which can be configured as either a cold air intake or a short ram intake. Some Typhoon's have high quality finish options including polished aluminum (part ends with TP), powder coated blue (part ends in TB), powder coated red (part ends in TR), and powder coated silver (ends in TS) among others. K&N intake systems replace your vehicle's restrictive factory air filter and air intake housing. K&N intakes are designed to dramatically reduce intake restriction allowing more air flow to your engine. More air means more usable power and acceleration throughout the engine's RPM range.
Cost: $323
Expected hp gain: 9 hp
What is the difference and why does the more expensive one give you less performance but cost more? It looks nicer I think (polished) but that doesn't fully explain everything in my mind.
