Difference between OEM Ford A-arm bushings and Prothane!?
1SickFox
Hey guys,
I need to replace the A-arm bushings on a '86 GT and was wondering if there was any difference between a OEM Ford bushing and say a Prothane set? Do they differ from stock Ford ones? I'd personally just put Ford OEM replacements in but i can't find any!? Does anybody know if they still make them?! Thanks!!
Here is a link to the ones i'm looking at.
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=PT-6209BL 1&comp=LRS
Yes, there is a big difference
Ford bushings are soft rubber. The Ford racing A-Arms that are now $300+ have a stiffer rubber bushing in them for improved handling.
The bushings in your link are polyurethane which is much stiffer than rubber. So there will be less movement. Downside is the stiffer bushings transmit more NVH to the vehicle.
So you need to decide if you can live with slightly more noise and harshness or if that is important to you to keep.
